Display blank? A6 c7
lukus89
Active Member
Hi guys... anyone had this? Any idea what I'll need to fix? It's the middle of the speedo and rev meter. Screen is on but blank.
I have VAGCOM / VCDS.
IMG 0228
Haven't scanned it yet
Scan it first, see if there any fault codes. If not then pull the fuse for the cluster, could just be a software glitch.
Cheers,
Will do. Haven't got a fuse map anymore which might make that a little hard. Any risk removing the battery connectors?
That will do the same thing, the fuses should be listed in the manual. If you disconnect the battery you may get the ABS light on until you drive the car and turn a few corners.
Brill cheers for the help!
