Disc locked in RNSE
blue10
I have a 2012 sat nav disc that appears to be ‘locked’ in the CD slot of my RNSE mk II; I have just upgraded to a newer sat nav disc and now need to remove the existing disc. Can the disc be ejected without VCDS (I know it probably defeats the object) or a making a trip to the main dealers? Thanks.
Dave
@udi A3
Well-Known Member
I have a function on vag commander to eject disc, never tried it though. Your welcome to pop over and try it
ninjakid
AFAIK you need a VCDS or take it to dealers to enable the eject button and also code in the new sat nav disk. I have the same issue.
hades-
Well-Known Member
quick codeing with vcds and you can eject as many times as you like
blue10
Thanks for your replies so far:
@udi A3 – thanks for the offer
ninjakid - I thought it was a case of enabling the eject button and then replacing the 2012 disc with the newer version; does the new disk also have to be coded?
bez101 – I have pm’d you
Dave
hades-
Well-Known Member
the disk doesnt need to be coded
im around between 3 and 6 tmoro
blue10
Thanks bez101, whereabouts are you based? I will be in Sheffield city centre between 3 and 6 tomoz.
Dave
hades-
Well-Known Member
top of city road
pm me a number ill txt you later today
@udi A3
Well-Known Member
vcds worked just as bez101 said for anyone else wondering!
Schlaag
Bwah
Can anyone help with describing the VCDS procedure to unlock the RNSE eject ?
