Disc and Pad change...just in time!
This isn't a particularly rock'n'roll mod thread but I thought it was interesting nonetheless. I've known for a while that my front discs and pads needed changing but haven't gotten around to doing it due to other higher priority jobs on my pug, but recently the pad warning light came on so I thought I best get it sorted. Anyway when I pulled the brakes apart yesterday this was the state of the existing pads, needless to say, if your warning light comes on, get 'em changed ASAP!
Old pad:
New Pad:
Comparison, both pads facing outwards:
It's no wonder I had to jump on the pedal to stop the thing!
finesse
Higher priority jobs on the pug? Travesty! !
NHN
Site Sponsor
Nah there's shed loads of life in those yet :p
DaveA3
Audi A-Trizzle!
pffft no sparks?
jokin thats pretty crazy i had some like that on my first car. Did know any better and just keep driving and driving. In the end they were literally like 1-3mm
damo.h
****** he'll, but more to the point whats with the black leather fingerless gloves :lmfao:
thegoal007
Another S3 owner....
well, looks like there's still a bit of life in them....but then again it all depends on the mileage you do.
Not sure what pads they are, but the standard pads from Audi have the sensor somewhere near the middle of the pad ! I always buy genuine when it comes to disks & brakes.
NHN
Site Sponsor
LMFAO only just spotted them, bit of YMCA going on here I fear
NHN
Site Sponsor
Your right or our right, cause there is a distinct difference lmfao
NHN
Site Sponsor
jojo
Looking for Boost!
Staff member
Moderator
I have to ask, does braking power really deteriorates as the pads wear down? Surely unless it's worn down to metal, it should stop just as good right? Also, brake pedal needing a bit more of a stomp to make car stop, doesn't the front brakes self adjust, so as the pad wear down, your brake fluid reservoir goes down as the piston needs to come further out, but brake pedal pressure should stay the same?
eddieantifreeze
The short answer is yes and no.
In theory the pad should be exactly the same from first (bedded in) stop to the last.
However, the resin in a pad is never completely cured, when pads are new the resin is roughly 80% cured. As you use the brake the resin cures more and more and so changes the friction coefficient of the pad.
As the pad gets thinner it is also easier to put too much heat through them and alter the chemical composion of them that way (I would get deeper into it but its slightly complicated as i dont fully know what goes into a pad - its a very closely guarded secret of pad manufacturers)
And yes you are exactly right that the brake reseviour allows for more fluid to go into the system as the pad wears and being an incompressable fluid pedal feel should not change....
Inertiauk
On an A4 I had years ago, I was skint after splitting with my wife, mine got way lower than that, my car sounded like a train stopping!
DaveA3
Audi A-Trizzle!
NHN
Site Sponsor
Recognise anyone:
