Disable DRL’s
BigJoeyC Aug 10, 2019
  1. BigJoeyC
    BigJoeyC Member
    40
    Hi
    Just got my Audi A4 59 plate. The only problem is i think the daytime running lights look naff. Them mutiple spot LEDs look cheap in my opinion. Is there a way to completely disable them?
  2. Avatar
    Google AdSense Advertisement
  3. Marky007
    Marky007 A4 Sline Team Silver TDi saloon Audi A4 S-line owners group Manual
    495
    155
    43
    Maybe with carista app
  4. jdp1962
    jdp1962 Grumpy Old Man TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 Black Edition quattro S tronic
    9,341
    3,952
  5. forty3
    forty3 Active Member
    418
    164
    43
    Carista will let you adjust the drl brightness. Not sure if there's a minium setting tho as didn't look.
  6. Marky007
    495
    155
    43
    You could just unplug them but you will get a error on dash I think they look good imo.
    DickoB8 likes this.
  7. BigJoeyC
    BigJoeyC Member
    40
    Is it as simple as unplugging them??
  8. A4A4
    A4A4 Owner of a Shiny Daytona
    900
    1,829
    93
    Carista will give you the option to turn your DRL's off and on.
    Mine are currently set to off for now.
    Bristle Hound and Marky007 like this.
  9. BigJoeyC
    BigJoeyC Member
    40
    Cheers man, new to the car. I’ll do this. Would look alot better if they were bright white instead of a yellowy colour! Seen a few posts showing that you have to take a stanley knive and cut the back of the headlight out to change the bulbs for the DRL’s. What a joke
    A4A4 likes this.
  10. Geoff Morritt
    Geoff Morritt Member
    55
    23
    I used the carista app and whacked the DRL brightness up to the max. They look pretty bright and white now.
  11. BigJoeyC
    BigJoeyC Member
    40
    Whats the carista app? Obviously an app but im taking it that it has to be linked to your car somehow?
  12. Avatar
  13. CHEZ
    CHEZ moderately amusing Supporter
    5,761
    1,208
    I noticed when you wack up the brightness on the DRL's with carista the 'wink' function when indicating does not work as it did.
    Also they tend to be more brighter than the headlamps lol
  14. BigJoeyC
    BigJoeyC Member
    40
    Just went to buy this off amazon and says its not compatible with my audi a4 2.0tdi 59 plate
  15. CHEZ
    5,761
    1,208
    It should be.
    Do you not know anyone who has it to try first?
    Where are you located?
  16. BigJoeyC
    BigJoeyC Member
    40
    Newcastle
  17. CHEZ
    5,761
    1,208
    Not really too far from me then.
    I live in Peterlee.
    I will gladly have a go for you for you if you drive up!
    No charge
  18. Marky007
    495
    155
    43
    Am in Newcastle but dont have paid app anymore ran out last month . . .
    Peterlee not to far you can do all you want to do in 5 mins . . .
  19. CHEZ
    5,761
    1,208
    Just been out to play with carista and the only adjustability now (for me anyway) is to adjust the led drl brightness when the headlamps are on.
    Which is weird, because it was possible before.
    Probably because it is always evolving I guess.
    So, sorry carista can't turn them off.
  20. Geoff Morritt
    55
    23
    You need to buy the carista dongle off ebay/amazon(or a compatible type OBDII dongle) and download the carista app to your phone. Connect the two via bluetooth and you can then alter quite a few things on your car...quite good fun!
  21. BigJoeyC
    BigJoeyC Member
    40
    Had the car less than48 hours and engine light csme on. Garage replaced DPF sensor and it went off itself. It has now came back on! Im guessing the car needs a new DPF or regeneration to butn the soot off. Its under 3 month warranty so i’ll be pushing for a new DPF
  22. HOGG
    HOGG Active Member
    407
    129
    43
    Good luck with that. Companies now offer dpf off cleaning, which makes your dpf like brand new for only £149.99
    Sent from my SM-G930F using Tapatalk
  23. Marky007
    495
    155
    43
    Vag dpf app is what you need . . . .
    Excellent app keeping dpf tip top
    Not sure a dpf will be in with warranty
    But definitely push for one....
  24. Bristle Hound
    Bristle Hound Moderator Staff Member Moderator Audi A4 Audi Avant Owner Group
    10,295
    14,696
  25. BigJoeyC
    BigJoeyC Member
    40
  26. CHEZ
    5,761
    1,208
    It probably will not.
    I had to get the genuine carista one to work
  27. BigJoeyC
    BigJoeyC Member
    40
    The carista app has the option for it. Ive already downloaded the app. Guess we’ll see
    According to amazon the carista dongle is not compatible with my car
  28. Bristle Hound
    10,295
    14,696
    @BigJoeyC - The ELM wifi dongle I got off ebay worked fine with Carista on my 2015 15 plate B8.5 S4 & also works on my 2010 10 plate A4 Avant
    Also worked on my old 2018 18 plate Leon Cupra too
  29. BigJoeyC
    BigJoeyC Member
    40
    Sounds good, its meant to work with pretty much any car so it should. Can use the carista app to connect and customize
  30. CHEZ
    5,761
    1,208
    Yeah one of them?
    Didn't work for me.
    Might for you though.
    Good luck
  31. BigJoeyC
    BigJoeyC Member
    40
    Looks slightly different to that, got like 5 lights on the top and its a wifi one which allows it to be compatible with an iphone
  32. BigJoeyC
    BigJoeyC Member
    40
    Car ELM327 WIFI OBD2 Scanner Engine Fault Code Reader Reset Adapter for iPhone IOS Android Windows,Auto Check Engine Light Clear OBDII Diagnostic Scan Tool
    Thats the one
    Do uou mean it doesnt work with the Carista app? Or just didnt work in general
  33. Avatar
  34. CHEZ
    5,761
    1,208
    Carista just didn't recognize it
    I use Bluetooth and Android though.
  35. BigJoeyC
    BigJoeyC Member
    40
    I’ll try it out and see what happens. If not il buy the Carista dongle and try that
  36. Marky007
    495
    155
    43
    Do you know how to return the wink function?
    What was original brightness setting 43% a cant remember
    CHEZ likes this.
  37. CHEZ
    5,761
    1,208
    Yeah you can if you return it to default value, which I can't remember lol.
    I don't think it was that high though .
    Marky007 likes this.
  38. BigJoeyC
    BigJoeyC Member
    40
    Do you happen to know what the original brightness of thr DRL’s are?
  39. Marky007
    495
    155
    43
    I have mine set to 80%
    But I believe this is only when main HEADLIGHTS are on
  40. BigJoeyC
    BigJoeyC Member
    40
    I’ll be turning mine to zero lol
  41. Mobzor
    Mobzor A4 S-line Black Edition Quattro
    47
    I messed about with the DRL brightness a while back, 80% at night was wayyy too bright and likely dazzles other drivers. Stuck it at 10%.
  42. BigJoeyC
    BigJoeyC Member
    40
    Is yours a B8 model?
  43. Marky007
    495
    155
    43
    I agree wanting to revert mine back to standard...
    B8.5
