  2. Dismiss Notice
Disable Auto Start/Stop via VCDS
idua3191 Sep 1, 2020
  1. idua3191
    idua3191 Registered User
    I would really love to disable this economy feature but have has no luck trying with the instructions from older models. It burps and farts and I don't believe it saves any fuel.
  2. Avatar
    snack-media
    Advertisement
  3. Gazwould
    Gazwould Registered User
    7,535
    3,047
    Exactly , lab tested a little to get the bonus figures , real world nothing , then there's the cost of the components it wears out quicker .
  4. psychopomp1
    psychopomp1 Registered User
    702
    212
    43
    No longer possible to disable it permanently using VCDS/OBD11/Carista etc on the latest MLB models. But I've gotten used to doing 2 things immediately after firing up the engine:
    1) Turn off start-stop
    2) Turn off lane assist
    Its now second nature doing the above :)
    Sean Byrne and mark fox like this.
  5. Longstride83
    Longstride83 Registered User
    249
    44
    It’s like pre flight checks
    psychopomp1 likes this.
  6. RAF_S7
    RAF_S7 Well-Known Member Gold Supporter
    1,948
    1,067
    Auto box on the S7 - Into Sports Mode = Start/Stop disabled :racer:
  7. DaveW
    DaveW Registered User
    1,456
    672
    Not sure why anyone would want to turn this off, better for consumption and better for the environment.
  8. Gazwould
    7,535
    3,047
    Nope..
  9. MPTT
    MPTT Registered User
    29
    Just put it in Sport Mode, that keeps the engine running. I don’t know why you’d want to disable it permanently, does yours not turn the engine off and let the car coast when you lift off? I think the longest ‘coast’ with the engine off is a few miles on the M62 down the hill from Saddleworth to Rochdale.
  10. idua3191
    Sports mode is louder and burns more energy so I will just have to accept as is. After having an A4, S4, R8V10 SQ5, RS3 and now the S6 I love the power but am not in love with the engine/exhaust sound. My only other complaint would be the that software is slow on start up-reminds me of Windows 8.
    I call it a rocket sedan and just love the car!
    Enjoy and stay safe everyone.
  11. Longstride83
    249
    44
    I’ve had it a few times on a hill where I’ve pressed the accelerator to pull away and I’ve rolled back before the engine starts again, nearly hit the car behind me.
  12. Avatar
    snack-media
    Advertisement
  13. cuke2u
    cuke2u Well-Known Member
    12,914
    5,244
    Myths about the start stop system are plenty and that video shows a complete lack of knowledge about how the systems are designed and operate and have no factual basis. It's almost laughable.
    Having all our cars idling whilst stationary is not good for the environment neither is is good for our health, with little to do with economy..
  14. elan2s
    elan2s Registered User
    582
    102
    43
    Do you not have the auto handbrake ativated? Also you can restart the engine by tapping the accelerator pedal before you want to move off so the starting up and moving off are not undertaken as a single process
  15. Gazwould
    7,535
    3,047
    OK , here's a mechanics view which echos Steve Cresswell's aka Crasher a VAG indi of 32 years .
    Thank God all I had to do is pull a fuse...
  16. Longstride83
    249
    44
    I find it to jerky so I don’t use it.
  17. Robuk
    Robuk New Member
    This hack works on my Merc and Porsche Cayman with no issues and works on my recently acquired Mk3 2015 TT coupe. Disconnect the sensor attached to the negative battery clamp.
  18. Gazwould
    7,535
    3,047
    Not on your Palladium silver Merc C204 with Ronal 18" alloys it doesn't Rob , you lose brake HOLD !
  19. Robuk
    Robuk New Member
    Of course you do Gazwould, it didn`t bother me as I never used or trusted it, if you watched the youtube vid it informs as much. As far as the Mk3 TT goes, everything works other than stop/start including electric hand brake and parking brake, the alternator also charges at a standard 14.2 volts as it did prior to the implementation of stop/start and the battery sensor. Without the sensor in play there is now no need to register the battery at change and it will now last at least double the length of time it would have if stop/start were functional. There is also the benefit of less wear on the timing chain as most stress is at startup when overcoming the moment of inertia.:icon thumright::icon thumright:
  20. Gazwould
    7,535
    3,047
    With the Merc 204's just pull the 7.5A fuse that's on the auxiliary battery , SS permanently deactivated and everything else works , I love brake HOLD .
    Ran like this for several months now and only yesterday took out the auxiliary battery for good , saved 5kg and it's worth something secondhand to the plentiful Merc OCD types who absolutely have to have a feature working even if it's fit for the bin .
  21. Robuk
    Robuk New Member
    That`s a good hack, never thought of loosing the battery, with the disconnect hack though you also get rid of smart charging, this is a real asset if you only use the car for short journey`s as the alternator is then always on continuous charging as in days prior to Stop/start. This ensures the battery is always fully charged at all times, my journey`s in the Merc were mainly local, battery is 8 years old and still takes a full charge. Two good hacks here, odd that my Mk3 TT is not adversely effected in any way with the hack, no warning lights nothing.
