Diesel emissions a joke....
Tony shev Jan 29, 2018
  1. Tony shev
    Tony shev New Member Audi A3
    9
    how doo people, how do you guys put up with when either the DPF goes tits up or the EGR gives up which mine has. Bought the car last November and regretting it.
    oh, my car is a 2011 Audi A3 tdi 170 black edition...
  2. Avatar
    Google AdSense Advertisement
  3. Gazwould
    Gazwould Well-Known Member
    6,545
    2,672
  4. Alan A
    Alan A Member
    46
    I had similar problems with my pd170.
    DPF blocked so I had to get it cleaned out, and also cleaned the EGR valve etc.
    I know it's expensive but I now use either shell v power, bp ultimate or esso, plus I use an additive, Archoil D Max AR 6900. I had the soot levels in the dpf checked last Friday and showed only 3%, so well happy with that.
  5. Gazwould
    6,545
    2,672
    Save a fortune and add 2 Stroke oil to the diesel.
  6. Retroman
    Retroman Audi A3 2010 Sportback 2.0 TDI 170 (CBBB engine)
    1,035
    326
    I've read the earlier PD170s had DPF issues. Three most common causes of DPF issues on the CR diesels are 1) wrong engine oil, 2) a car only doing short/slow speed journeys and 3) EGR (e.g. blocked/stuck) which eventually results in DPF issues. Not had any issues with my CR170. Problems with injectors or failing turbos, dumping either extra fuel or oil into the system, can also cause problems.
  7. RSTHRILLER
    RSTHRILLER LOVE 5 BANGERS
    214
    51
    blank egr and delete dpf jobs done
  8. Cornish John
    Cornish John Active Member Silver Supporter Team Silver TDi Audi TT quattro Sportback Coupe
    154
    62
    Same!
    Its now got 244000 on the clock, still no problems and looking forward to my little 160 mile drive each way tomorrow, I know the car wont fail me!
    Changed the oil again this morning along will new front pads, oil had only done 5000 miles that was in there, cant beat changing that oil as often as you can.
    My son as just bought the same car as mine, with only 112000 miles, will be interesting to see how it gets on!
    I wonder what Audi Gazwould drives, seems to know a lot about failed motors lol
    Retroman likes this.
  9. Gazwould
    6,545
    2,672
    Finally the penny drops for VAG .
  10. Cornish John
    154
    62
    All about common sense I believe!!
    The more you service and look after your car, the longer its going to last!
    Not rocket science, or do we all need spoon feeding these days.............................
    Well, as an engineer in the Royal Navy for 32 years its worked for me!!!!!
    Gazwould likes this.
  11. Retroman
    1,035
    326
    Remember when I was a kid, working on my old car, and by old dad would bring his friends around (all aircraft engine engineers) and they would pat me on the head and say "young retroman. the finest thing you can do to the engine is to change the oil twice as frequently as recommended". :highly amused:
    Cornish John likes this.
  12. Avatar
  13. Mario
    Mario Active Member TDi Audi A4 quattro S-line owners group S tronic Manual
    470
    179
    43
    Where did you get that from?
  14. Ash79
    Ash79 New Member
    9
    If it helps my 138hp was regenerating quite often, was dreading the DPF problem.
    After parking up at home after work the car would be revving up over 1000rpm and the fans would be running.
    Now I use Shell V Power and go the motorway for 10 mins on the way back from work and keep it above 2000rpm.
    Car is running much smoothly, quieter and no more regens when I park up.
  15. Cornish John
    154
    62
    I visit my Dad once a week, 150 motorway miles each way.
    That's the key I'm sure.
    245,765 miles now.
    mxnrg likes this.
  16. Ash79
    Ash79 New Member
    9
    Yowzers! 245,765 miles!
    Excellent, fills me with confidence then, mines just a pup with 37,000.
    The diesel engine is excellent but with these dpf's attached they need to be running 2000 rpm+ consistently to burn that soot off.
