  2. Dismiss Notice
Dead Pixels on Centre Screen
ScottishA4B9 Nov 21, 2020
  1. ScottishA4B9
    ScottishA4B9 Registered User
    3,648
    1,060
    Hi all.
    I noticed I have some dead pixels on my central screen. Has anybody else had this?
    Not sure if it’s enough to concern me changing it but replacement screens seem to be cheap.
    https://ibb.co/2Pqd54P
  2. Avatar
    snack-media
    Advertisement
  3. jrumball
    jrumball Registered User
    696
    359
    That’s a good example of dead or stuck pixels ! If it’s under warranty I would get it fixed . The odd one from new is normal depending on the quality of the display but grouping like that around the edges may be it staring to fail ....
  4. NHN
    32,016
    2,413
    Just grab a used screen & test.
    ScottishA4B9 likes this.
  5. Dubjam
    Dubjam Moderator Staff Member Moderator VCDS Map User
    1,170
    427
    Excuse for a MIB2 upgrade :)
    or at least a Mib1 Tech pack upgrade
  6. NHN
    32,016
    2,413
    Hacked 2, but yes lol
  7. Bigjase88
    Bigjase88 Registered User
    223
    75
    Whats an MIB1 tech pack upgrade
  8. Dubjam
    1,170
    427
    Widescreen, HDD based Sat Nav, Touch writing input
  9. Bigjase88
    223
    75
    Who knows i have the small screen sat nav
  10. Dubjam
    1,170
    427
    Who knows if you have the small screen? Do you mean how do you tell which screen/sat nav you have?
  11. Bigjase88
    223
    75
    I have the small screen with sat nav, i just don’t understand MIB1 MIB2
    is that not the men in black movies that will smith starred in?
  12. Avatar
    snack-media
    Advertisement
  13. Dubjam
    1,170
    427
    MIB1 - PFL
    MIB2 - FL (Carplay etc)
    MIB - Modular Infotainment System - The unit in your glovebox with the SD cards, basically a small PC
  14. ScottishA4B9
    3,648
    1,060
    I defo think so! Need to see what prices are. I keep seeing adverts for Leicester VAG retrofits and they seem to do it all. I think it’s cheaper if you source the parts yourself individually on eBay. I would just need to know exactly what all I need. If anybody can help, that would be awesome.
  15. Dubjam
    1,170
    427
    Around £1200 for MIB2
    MIB1 HIGH with Screen, maybe £500?
    I've posted all the part numbers needed for a MIB2 before, just use the search engine or look at my previous posts.
    They will both need to be hacked to use on your car.
    I notice on this 'Leicester VAG coding' facebook page they are selling a MIB2 upgrade for £1300 , however it comes without the BO V2 amp and fitting bracket that you'll need to get full control over your sound. You'll also need to then send the MMI Controller console to me to covert to RED LED's to match your PFL dash as otherwise the MMI controller will be WHITE LED's and your dash LEDS', RED, which looks absolutely pony.
    They offer to fit and code for £100, which is remarkable.
  16. ScottishA4B9
    3,648
    1,060
    @Dubjam What’s the difference of the MIB1 HIGH over what I’ve got?
  17. Dubjam
    1,170
    427
    Widescreen with higher resolution (how it should have been rather than the poverty spec 1985's screen of the standard one), better graphics, touch input, HDD based Sat Nav (faster) - can be hacked so free map updates for life, Speed camera POI's can be added, internal HDD for music
    There may be some other things as well..maybe DAB? I dont know if that came standard on the poverty spec MIB or not
  18. ScottishA4B9
    3,648
    1,060
    @Dubjam I think DAB is standard, looking back at the brochure from the time.
    I think MIB1 would be a good bet especially if you say it’s around £500. I think MIB2 would be too much although I would love Apple Car Play. I had the Tech Pack high and VC in my A4 B9 and loved it! (Not so much the dial with writing pad though!).
    I see VC’s on eBay for quite cheap but I know it wouldn’t be a straight forward or easy thing to do.
  19. ScottishA4B9
    3,648
    1,060
  20. Dubjam
    1,170
    427
    I love the Touch input! So much easier than using the dial, which is beneficial for the MIB2 as its address entry interface is poor, the MIB1 was better in that respect.
    I think it would essentially be plug and play as long as the unit is hacked.
    Looks like a pretty decent deal! However you'd have to check with a pro about it being the correct region for the UK. You may need a firmware flash.
  21. ScottishA4B9
    3,648
    1,060
    Do you mean the VC?
    Thanks for the advice so far.
  22. Dubjam
    1,170
    427
    MIB1 dosent have VC function. Im talking about the MIB unit itself, has to be hacked/CP protection removed to use on a different vehicle.
  23. ScottishA4B9
    3,648
    1,060
    Gotcha. I think the MIB1 will be the way to go.
  24. Bigjase88
    223
    75
    I have MIB1 with Nav and DAB.
    of the time (2013) it wasn’t a bad set-up, in 2020 it lags in the past but thats technology, 7 years time the new stuff will looks **** most likely
  25. CanadaA3wales
    CanadaA3wales Canadian living in South Wales - Audi A3 8V 150BHP
    756
    172
    43
    I have MIB1 and it has great DAB, Bluetooth has never let me down, the sound quality is decent.
    Not one thing has failed on it, so cannot see the reason on spending over £500.00 just for a little bigger screen.
    If I want satnav I will buy a proper one or google maps on my phone for free.
  26. Dubjam
    1,170
    427
    There are two Mib1 boys, Mib1 with the poverty spec screen and sd card sat nav, and Mib2 high tech pack with the 7” screen abd hdd sat nav. The latter is perfectly up to date.
  27. CanadaA3wales
    756
    172
    43
    Yeah I know, I am very poor so have Poverty spec LOL
    I think it suits my needs and cant think of anything else I need it to do.
    If I got a deal on a 7" screen for £200.00 I would probably buy it, but for £500.00 plus install and coding, no thanks.
    There is actually 3
    MIB Normal - Which I have
    MIB1 High with the 7" for about £500.00 used
    and MIB2 which is like £2000.00
  28. Bigjase88
    223
    75
    Im also poverty spec.
    it doesn’t bother me as i would never use the Sat Nav on it anyways. It gets DAB what more does one need, i spend 95% of my life driving a Citroen van so anything is technologically advanced compared to that
  29. CanadaA3wales
    756
    172
    43
    Exactly
    I can change my music on the steering wheel, listen to DAB, take calls, Deezer ect ..
    I would like the virtual dash, but that will be some time away before I can afford it lol
    I have seen the sat nav on cars and they are so bad, I cannot understand how people spend over £500.00 on them, but the google earth maps which Audi took away looked amazing, but obviously Audi does not want to pay the google prices anymore, or whatever the reason.
    If it aint broke, dont fix it.
  30. Dubjam
    1,170
    427
    I said there was two Mib1,s. You have read the content of this thread yeah? Lol
    i had Mib1 Tech pack and upgraded to Mib2, it doesn't cost £2000. This was probably a decadent upgrade but i would definitely not hesitate to do a Mib1 tech pack upgrade at all, thats more necessity imo.
    The standard Mib1 SD was so bad, it like a Spectrum ZX graphics. Did not belong in the interior of an 8V.
  31. CanadaA3wales
    756
    172
    43
    I agree with the graphics, my 2011 golf had a far better screen than my 2014 Audi, but it works.
    Well if anyone has a 7" screen unit MIB High for sale give me a shout, but wont be paying £500.00 for it.
  32. Dubjam
    1,170
    427
    £500 for a MIB and screen is great value. A worthy upgrade. I would imagine you'd wouldn't be getting one for any less, if you want cheaper replacement parts, other manufacturers do have lower price used parts, such as Vauxhall :)
  33. Avatar
    snack-media
    Advertisement
  34. CanadaA3wales
    756
    172
    43
    LOL get me a nice used ford pinto screen.
    First and formost is rear camera and front sensors with DJALEX in the new year.
    I wish I had access to a good scrap yard to keep an eye out for a used unit, that would probably be around 250.00, but dont think there are any around me apart from copart, but they only sell car TL and they are in bristol.
  35. Dubjam
    1,170
    427
    Gone are the days when you could roam around a scrap yard, remove bits from loads of cars, take them the cash desk and just get charged a few notes. those where the times, so much fun.
    Rear camera - biggest waste of money ever, I wish I never did mine, its more annoying that anything else , and a rear camera on your tiny low res screen?I wouldnt bother at all.
  36. CanadaA3wales
    756
    172
    43
    Would you say just go with the sensors instead?
    Ive seen some videos and the pictures dont look too bad, but again have not seen it in person.
    Kind of going off topic here lol
  37. Dubjam
    1,170
    427
    I think @ScottishA4B9 is sorted in what he needs now , so no harm.
    Honestly, try to see a camera in person on a poverty MIB. It's really not to hot. Some people like camera's, I just find them dangerous.
    The sensors I have turned down to about 25%. If you cant drive and park a car without sensors, then you need to go back to driving school.
    That being said, I would choose front and rear sensors over a camera any day. But Id choose a MIB upgrade over sensors.
  38. CanadaA3wales
    756
    172
    43
    No accidents yet in the audi.
    Believe it or not, I had sensors on my golf and still hit my garage door lol.
    So 500 for a MIB high unit, how much do you think it would be for a install?
  39. Bigjase88
    223
    75
    Whats the point in throwing good money after bad, i will just buy a newer A3 next time around, maybe an S3, only got the A3 s-tronic as the missus needed an auto to learn to drive, (can’t do gears)
  40. CanadaA3wales
    756
    172
    43
    Can't afford a decent year S3, even £10,000 probably wouldn't buy you a 10 year old S3 which I think is highly over priced for what you get.
    I'm happy with my A3, it's decently fast and does exactly what I need.
    I'm happy upgrading little bits to suit my needs.
