How easy are they to fit?
Could you let us know how you get on please epox
They are easy to fit, if I can do it on my own on my drive, then anyone can! That's if you fit them on the bottom. It's much easier to adjust them to the length of the original arms before fitting, two blokes and a ramp would make it a doddle.
To add a spanner in the worksâ¦.Dave told me topâ¦..
I did mine top, harder to do, but you dont have to mess with the sensor, + aligned fine, as jo says you get a little more adjustment from the bottom..
Just read a thread on the TT forum about a member there fitting KW ARTB's and it was noted that at the hub end the steel was 2mm thicker then OEM, thus requiring different length bolts (the owner managed to source 2 more INNER bolts as these are a bit longer).
Is this the same case with Dave's bars?
