Data logging?
AudiB720TS Aug 7, 2018
  1. AudiB720TS
    AudiB720TS Active Member
    128
    45
    Can I do data logging with a VCDS/VAGCOM cable and software? I want an indication of air/fuel ratio and other sensor data through the RPM range, output to text file like CSV or otherwise.
    I previously bought some VAGCOM cable from a CN vendor and it wouldnt do anything. What are you guys using?
  2. Avatar
    Google AdSense Advertisement
  3. Sibmets
    Sibmets Member
    51
    You can use VCDS to log any data and output it to CSV. I personally use Obdeleven for my VCDS needs - including data logging - as it does everything that VCDS does. Here's an example from Obdeleven when I was trying to diagnose boost fluctuations.[​IMG]
    Sent from my E5823 using Tapatalk
  4. AudiB720TS
    128
    45
    Thanks, but I don't use Android devices.
