  2. Dismiss Notice
Data Connection
DaveW Dec 11, 2018
  1. DaveW
    DaveW Well-Known Member Team Floret Silver S-line owners group Audi A6 Audi Avant Owner Group
    1,346
    623
    Hi folks,
    In anticipation of collecting my new A6 Avant tomorrow, I was wondering what data connection you are using?
    I am wanting to use web radio on the MMI and Spotify on my mobile via the Smartphone Interface. Will the built-in SIM allow this, or will I need to use the "Carphone" Bluetooth profile with my RSAP mobile?
    Thanks,
    Dave
  2. Avatar
    snack-media
    Advertisement
  3. DaveW
    1,346
    623
    From my own experiences I've gathered that:
    • Hands free connection won't allow web radio to work
    • Carphone allows web radio but can't get weather or news to work
    • Plugging in Android Auto takes over the phone connection and Bluetooth need to be turned off to allow spotify to work.
    Can anyone else share their experiences?
    Thanks,
    Dave
  4. DotNetDude
    DotNetDude Active Member S-line owners group TDi Audi A6 Audi Avant Owner Group
    180
    79
    Essentially, any streaming services will require your own data. Everything else will be via the car eSIM. The eSIM allows news, weather, connections to the server for voice and whatever, and also everything for the sat nav, including traffic and sat nav updates. I know this because, just last week it prompted me to do a map update, and it updated all European maps via the eSIM; it did it pretty quickly as well.
    If you provide that data connection, then all data for the car goes through that data connection. So whether it be using a SIM you plug in, or RSAP to your phone, once you connect it, that'll be the data source for the car. It does warn you that when connecting. So, if you are fine with that, then yes just go ahead and connect it up.
    I haven't tested this but, I am pretty sure that if you connect via android auto, then it just makes use of the data connection from the phone via the cable, irrespective of whether it was connected via bluetoooth (RSAP) or not.
    I currently have a throw away sim I leave in the slot and just push it in when I want to use streaming. Haven't tried android auto with the touch screen interface yet. I really didn't get on with AA in the A4, but maybe it'll feel better with the touchscreen...
  5. DaveW
    1,346
    623
    I realised this morning that I hadn't logged into Audi Connect on the MMI, which explains the lack of weather etc.
    The only issue now is Android Auto, which, as you say grabs the data connection. So it's not possible to listen to MMI Web Radio and view WhatsApp messages. Then again, I am supposed to be concentrating on driving....
  6. DotNetDude
    180
    79
    Yes, the Android Auto connection is a bit annoying. If you leave AA running, you get full voice control of What's app, so when IMs arrive, it'll notify you and you can listen to the message(s), and can also respond all by voice control.
    I will run a test when I get a chance to see if the external sim makes a difference. I can try connecting the sim, then connecting a cable and running AA, then switch back to the MMI and see if I can run the web radio.
  7. DaveW
    1,346
    623
    Great, spent lunch time setting up shortcuts and doing some other settings, stuck in the office now so can't do any more mucking about in my car :rage:
  8. DaveW
    1,346
    623
    Decided not to bother with Android Auto for now, it offers nothing more than the MMI can do.
    I've decided to dump Spotify (which was the main reason for using AA) and gone with Amazon Music, it works well via the MMI so far.
  9. Sam77
    Sam77 Member
    42
    13
    I was also hoping for better Spotify integration rather than using via AA or Bluetooth. I've tried Amazon music using the app in car but I get a "failure to connect" each time. Has anyone else had this problem?
  10. DaveW
    1,346
    623
    Amazon works fine for me. I use RSAP Bluetooth profile to my S9+ and a WiFi connection to the MMI on my phone. Also logged into Amazon Music in the MyAudi app on the services menu.
  11. Sam77
    Sam77 Member
    42
    13
    I'm able to load up Napster (unfortunately!), news feeds with my own RSS added, station prices and weather etc but not Amazon. I'm logged in on the MMI as well as the MyAudi app. The app detects Amazon as logged in. Even with my phone plugged in using AA i still can't get a connection to Amazon Music. I assume that because Amazon music is part of the Audi Connect services that it would be able to use the data connection that is pre-existing in the car without the need to root my phone for remote sim access or use another data sim.
  12. Avatar
    snack-media
    Advertisement
  13. DaveW
    1,346
    623
    In order to work, Amazon needs either:
    • A data plan purchasing for the inbuilt eSIM
    • A separate data SIM
    • An RSAP Bluetooth compatible mobile connected
    Cheers,
    Dave
  14. Sam77
    Sam77 Member
    42
    13
    Thanks Dave, a bit annoying that it is supported by Audi Connect services but is the only app that requires a data package.
    It looks like i'm going to have to root my phone for RSAP seeing as I have an unlimited plan already in place.
    DaveW likes this.
  15. DaveW
    1,346
    623
    Good, the only issue I have is leaving home, the phone is still connected to the home WiFi, so myAudi doesn't start automatically. It's a shame you can't prioritize a WiFi connection, so I would give priority to the car WiFi over my home one. There's a 3rd party app that does, so may give it a go.
  16. Simonwhite2000
    Simonwhite2000 2017 S5 Coupe Daytona Grey
    656
    452
    Guys, do you have to log in to Audi Connect ie using the scratch off number etc to activate Google maps?
  17. DaveW
    1,346
    623
    No it should be activated by default.
  18. Simonwhite2000
    656
    452
    Ours doesnt seem to be. I will have a play around. It was really easy to find the setting in my S5 not so in this A6!
  19. DaveW
    1,346
    623
    I think the option you are looking "Satellite View" in the MMI
  20. DaveW
    1,346
    623
    In the map view > settings > map settings > Satellite map
  21. Simonwhite2000
    656
    452
    Thanks mate - how are you finding the A6?
  22. DotNetDude
    180
    79
    Sam, why do you say you need to root your phone? If you have an android phone, it should just be a standard feature, unlike iPhones where it isn't available.
  23. DaveW
    1,346
    623
    I'm loving it, I want to be in it all the time. Was mucking around with the cargo bay configurations earlier and had a go of driving in manual mode yesterday.
  24. Sam77
    Sam77 Member
    42
    13
    There are only a handful of phones in Europe that come with RSAP already enabled out of the box, mostly Samsung 8-9 series. The Qualcomm Bluetooth chip on my phone supports RSAP but I need to be a root user to enable it.
    I was looking at installing LineageOS a while back so now I have a reason to give it a go!
  25. DaveW
    1,346
    623
    Out of interest Sam, what phone do you have?
  26. DotNetDude
    180
    79
    Yes, I'm also curious to know what phone it is?
    RSAP has been around as long as I can remember, however its also fair to say, I've only had Samsung phones for the last few years. The first phone I connected up to make use of RSAP was an S5, so I made the assumption that it was now available on every non-apple phone. It hadn't occurred that other manufacturers wouldn't make it available.
  27. Sam77
    Sam77 Member
    42
    13
    LG G6 guys. Like i said most phones don't come out of the box with it pre-enabled in the OS and different region models have various features enabled or disabled.
  28. Sam77
    Sam77 Member
    42
    13
    So I have just taken delivery of my new S9+. Could someone provide what settings are required on both ends to get RSAP working correctly? I've seen Bluetooth tethering in the phone options, is there any additional setup required in the MMI?
  29. DaveW
    1,346
    623
    When you've connected your phone, go to settings > connected devices then long press the S9+ on the MMI menu. Make sure "carphone" profile is selected - if memory serves me well...
