Dashcam installed!
Buxton2901 Jun 9, 2018
  1. Buxton2901
    Buxton2901 Well-Known Member
    1,279
    566
    So I installed a dashcam today but I'm not happy with the cable routing as the only 12v power source seems to be in the arm rest.
    Meaning the cable has been routed under the headliner then under the a Pilar trim under the dash and long the centre console which is ok as its tucked away, but then the cable has to come up on the outside of the centre console trim and into the arm rest. Looks tatty imo.
    Is there a better way to wire this up?
    I know you can get a hardwire kit which will mean I could wire it into the fuse board on the passenger side of the dash.
    Some pics attached[​IMG][​IMG][​IMG][​IMG][​IMG]
    Spiedhermonkey likes this.
  2. Avatar
    Google AdSense Advertisement
  3. Spiedhermonkey
    Spiedhermonkey Active Member VCDS Map User
    184
    Looks discreet enough from the outside. Which one did you go for?
    Buxton2901 likes this.
  4. DonkeyIce
    DonkeyIce Member
    94
    68
    How many magic trees!! Lol
  5. Buxton2901
    1,279
    566
    I have a bit of a reputation for collecting magic trees lol
    Last time I had my A4 in for an MOT they took them all down and I wasn't a happy bunny!!!
    DonkeyIce likes this.
  6. Gazwould
    Gazwould Well-Known Member
    6,482
    2,631
    What's the orange bits on the camera ?
    Would be even more discreet if you had a top tint .
  7. Buxton2901
    1,279
    566
    It's the bloody writing on the cam. Says 1080p and something else. Might try to colour it In with a black Sharpie pen lol
  8. Gazwould
    6,482
    2,631
    Yeah alot of cameras are like that , bright red lense housings etc .
    The culprit..
  9. Buxton2901
    1,279
    566
    That's the one roav is the brand.
    Video quality is fantastic though
  10. marriedblonde
    marriedblonde Well-Known Member
    4,563
    230
    If you run the cable down the passenger side of the car, there is a fuse box at the end of the dash. I added a life feed from there for mine.
  11. Buxton2901
    1,279
    566
    How did u wire it into the fuse box?
    And which fuse did u use?
  12. Avatar
  13. marriedblonde
    4,563
    230
    I used one of these connectors that plugs into the fuse block so you can take a live feed. If you need on drop me your address via a message on here and I can send you one out
  14. jobu72z
    jobu72z New Member
    I recently did my own custom install ... tied into the power in the sunroof module. Drilled a little hole in the mirror cover for the USB power cable. Very clean.
    I tried posting a link to another forum where I posted it, but the site thinks I am trying to spam. I will post pics later.
  15. Tomo71
    Tomo71 New Member
    As above - but run to the drivers side, or at least, check fuses on either side power off after ignition is off (may take a minute or two) - i believe that the passanger side only has live all the time fuses, drivers side has both.
    Mine runs from the drivers side (with piggy back fuse tap) onto a hardwire kit (from Amazon), up the A pillar (the edge nearest the door) and then UNDER the airbag and A-Pillar trim and then tucked into the headliner. The only wire I see is when I open the door, can just see it making its way from fuse box to A pillar.
  16. DarkShadow
    DarkShadow Member
    92
    31
    Hey Buxton,
    My install is pretty similar to yours, I honestly don't mind it but if you want it running whilst parked, it's definitely the better option.
    Would be interesting to see this.
  17. jobu72z
    jobu72z New Member
