Help Please DAB just vanished!!!!
777GE90 Oct 12, 2018
  1. 777GE90
    777GE90 Member
    89
    So my Dad drove my A4 B8.5 (2014) a couple days ago, he had played around with the radio settings as when I came back it was on one of the frequency wavebands. Didn't think much of it but went back to my favourites and selected my saved DAB radio station, all was normal, the station worked fine. However, the volume was too loud so I decided to adjust it, this is when the problem started. Instead of the volume getting adjusted I got the volume bar displayed and "currently unavailable", I tried to turn the MMI on and off and the car too, but it just was not having it, it would not let me adjust the volume.
    So I went into the radio list and picked another radio station, there I could adjust the volume fine. So I then went back to the favourites DAB station and still same problem, cannot adjust volume. Then I thought maybe if I add the station manually back into the favourites it will fix the problem.
    So I pressed the "Waveband" button and lo and behold, the "DAB" option has vanished!!!! I can no longer search for new DAB stations, I can only play existing DAB stations in my favourites and cannot adjust the volume on them :(.
    Anyone had this happen to them before? How can I fix this? I am completely surprised that such a thing is even possible, the DAB radio stations work perfectly fine but it simply does not let me find new ones or adjust the volume anymore. It's like the software has confused itself and will no longer display DAB options.
  2. Avatar
    Google AdSense Advertisement
  3. 777GE90
    777GE90 Member
    89
    Ok finally got it back!
    This problem has been present for the last two days and would not go away. I proceeded to jump back in the car after posting this and went into the MMI main menu and in there ran a factory reset on the radio. Tried the radio again and still no luck in getting the DAB option back. So feeling defeated I went back indoors and had a shower. Afterwards I thought I would run an ODB scan to see if there was some sort of hardware failure, jumped back in the car and the DAB option magically appeared again :).
    Was starting to get worried as I was reading online that someone with an A3 had the same problem and Audi could not even fix it with a software reset so they proceeded to replace the entire MMI unit (at a potential cost of £2000+).
  4. rum4mo
    rum4mo Well-Known Member
    1,773
    408
    Did you scan it with VCDS or similar VW Group specific scan tool to see if anything had been logged?
  5. 777GE90
    777GE90 Member
    89
    I don't have anything as fancy as VCDS, just a Bluetooth OBD scanner which I used and came back with no logged faults.
    Really odd behaviour to be honest, I'm surprised something like this can even happen (and a simple reboot doesn't fix it).
  6. rum4mo
    1,773
    408
    It was probably due to your scan tool not being able to access the infotainment system that lead to no faults being logged/found/read!
