DAB disappeared after firmware update
Urhavinalaf
Wondering if anyone can assist.... Just updated firmware/nav maps on my 2011 model MMI-3G+ It was still on original install so figured there would be much to gain from an update!!
That turned out to be a mistake as I seem to have lost DAB radio. The others bands work fine but DAB and volume for it do not respond. I just see 'ensemble 1' and no progression from there.
I've gone from version HN+_DAB_K0097 and 5.12.5 to HN+R_EU_AU_K0942 and 6.34.1 Does the omission of DAB from that command line mean anything does anyone think?
I had a couple of errors in the firmware update which I had to skip/cancel to allow install to complete which I'm assuming must be playing a part -
ARU9440:0 error 131
KBD_FC7:0
Anyone any ideas for a fix? I've had a trawl for similar issues but they seem limited to cab/soft tops with wiring issues and various plugs working loose etc. I find that a bit too coincidental when it was working two minutes before the update.
I also understand a few don't really value DAB anyway but I just like things to work as they should :)
Thanks for any input!
Mike
Urhavinalaf
Resolved in case anyone finds this in a search for similar issue - file or sd card problem. Put firmware file onto new sd card and worked fine.
