  2. Dismiss Notice
Da Starter kit
Tj 0785 Mar 30, 2020
  1. Tj 0785
    Tj 0785 Registered User Bronze Supporter Silver Supporter VCDS Map User
    3,916
    1,206
  2. Avatar
    snack-media
    Advertisement
  3. jassyo06
    jassyo06 T-Cut King !
    19,699
    40,307
    Try and get one with a 15mm throw and 800/900watt motor it'll correct the paint quicker making life a little easier the one your looking at has a 9mm throw...which doesn't cover larger panels as quickly, menzerna,scholl,sonax are excellent compounds 250 ml bottles are ideal to start with and will last you some time and no it doesn't matter what colour of paint you have on your car,you'll also need a cleanser spirit to make sure corrected paint is free of used compound before applying a wax or coating of your choice otherwise it wont bond to the paint
    V6_Man likes this.
  4. SPIKE_JCW
    SPIKE_JCW Vorsprung durch Technik
    2,097
    2,245
    You still recommend the Flex machine @jassyo06, or do you think it is not worth the money? I know you’ve recommended the Das pro6 machine, albeit a bit noisy!
    jassyo06 likes this.
  5. jassyo06
    19,699
    40,307
    Flex is awesome but a stupid price aimed at the serious weekend warrior with a bit of money to waste...? But mainly for pro Detailers,the das6 pro 15mm throw machine is a great all rounder but it does go louder mainly because of the inferior internal components a flex or Rupes machine are better engineered internally
    All das6 machines are made in China.....!!!!
    SPIKE_JCW and V6_Man like this.
  6. Kayobong
    Kayobong Registered User
    815
    748
    93
    The one you recommended me a good year ago now is an excellent DA, still using it! I’ll try and find the link
  7. Kayobong
    815
    748
    93
    Sandra likes this.
  8. Tj 0785
    3,916
    1,206
    for the same price it’s either the clean your car das 6 pro plus 15mm throw Or the in2deatailng das 6 21mm throw both 900w would the 21mm be easier to use ?
  9. jassyo06
    19,699
    40,307
    21 mm is the more difficult one to use as it has far more movement in the pad backing plate ....ie centre to edge it moves 21mm as it spins les control 15mm is ideal
    Tj 0785 likes this.
