After a while on my "to-do" list, finally got it ordered, made, delivered and bow fitted.
Contacted royalsteeringwheels with required custom steering wheel I'm after and got the quote.
Discussed rest if the details and placed the order.
They were an a break so it took them just over 2 weeks to finish the wheel and ship out
Unfortunately, they made it to their standards, not to my original request, which they forgot about.
Week of email exchange and phone calls for them to finally admit, their fault and agreed to re-do the wheel.
It came back just before they decided to close down.
Wheel is custom made with flat bottom bit, covered with perforated leather at the top and sides. Charcoal alcantara covers flat bottom bit.
Seams are like hour marks in the clock, not straight/horisontal, like they did originally.
Just like that way better.
Red stitching toos it all up nicely.
As an exchange wheel (ordered custom and send them back mine after replacement) it set me back £320 but £100 is a refundable deposit so it will be £220.
Tenner was also a shipping fee on top of that.
Ordered also gear gaitor in alcantara match the wheel @ £40.
To the replacement:
With engine running, turn the wheel sideways to reveal screw caps at the back if the wheel (forgot to take picture of them properly)
Remove them both. Just push them back
Removed the Sline badge.
At this point, I have unplugged negative terminal of the battery, to be safe.
Spanner size 10.
With screws uncovered, T30 unscrews them both. Screws should stay in the wheel but may pop out.
You can now pull the airbag.
Lead to it is short but you can put it aside to have more access to the yellow connector.
That yellow connector have a pink tab which you need to pull to you.
Pull the black one apart also. With this one, remember to lay it flat at the back of the wheel, when reassemble it.
Steering wheel controls just slide to the centre of the wheel and their wire easily pulled out, once internal surround frame is pulled out.
T55 to unscrew the steering wheel holding bolt but before you do that, mark the steering wheel column to put it back together in the same groves.
Now the steering wheel can be just pulled out and replaced.
New wheel fitted and all back together in reverse order.
Before the airbag install, I've checked it around and found horn wire slightly bend.
That will require more force or bigger slap on the airbag to sound the horn.
Bend it back to straight and popped back in.
Makes the difference.
Big difference in interior appearance with that wheel in.
Still got the slight glue whiff of the wheel in the car but it will go away soon.
Sent from H P20 PRO
To the replacement:
Spanner size 10.
Sent from H P20 PRO
