Hi guys
I just switched from uni stage 2 dwna beta map to custom flex with ds1, so figured I’d put a thread together
Received my exclusive merlin purple on lunar silver sportback in October 2020. Immediately flashed the uni ecu as it was only stage 2 offering available at the time
Since switching to ds1, the gain in performance and smoothness is huge. And lucky I did switch, the Uni map was doing some weird things on dyno like over boosting and knocking at redline on some runs
Glad to be on a custom tune specifically for my car, e85 is available at pump here and good quality too
Some cool tricks with ds1, such as using the power gauge to display the ethanol content, and returning all the right over run/dsg upshift/startup noises from the PFL days
Initially I felt the car was a bit too fast for street/hills, accelerating off a corner the torque was like a smack in the face. My tuner on the day also made a more linear torque map, I’ve since switched to that map and it’s a lot nicer, car builds boost off a corner and feel like I flow corner to corner a lot smoother
Will get used to the power then look to do a tte700 next, shoot for around 420 awkw and keep torque at 700nm but across a wider band
Pink line is uni map
Parts list to date:
- TVS stage 2+ TCU
- Wagner dp + 2x 200 cell midpipe
- Eventuri stage 3 intake + inlet
- forge intercooler
- NGK plugs
- stock catback and injectors
- AP racing 6 pot bbk front and rear from Reyland (custom painted calipers)
- square 245/35 ps4s on staggered oe wheels
- H&R rear sway + superpro end links
- asr exhaust valve controller
Few things I’ve learnt along the way
- srm billet throttle inlet won’t fit dwna
- uni seems to have stopped development for dwna, there is still only a single stage 1 and 2 98 map
- uni’s tcu tunes are garbage. Their stage 2 tcu has this artificial kick in the back feeling like an old semi manual set to fastest shift speed (or for anyone like me who owned an f80 m3 dct, exactly like that with trans in sport plus)
- oe exhaust valve operation has both valves open in 1st, then closes one valve below 4k rpm in all other gears. You’ll need a controller to have both valves open full time in dynamic or you can have ds1 tuner customize the tables (i prefer the oe operation, then having option to open both in right mood/setting)
Quick Sound clip here with oe valve operation
Parts list to date:
- TVS stage 2+ TCU
- forge intercooler
- NGK plugs
