  2. Dismiss Notice
Curious about my MOT smoke test results?
SDHA4SLine Jun 24, 2015
  1. SDHA4SLine
    SDHA4SLine Well-Known Member Team Silver S-line owners group Audi Avant Owner Group
    2,613
    523
    Hi,
    Had my MOT yesterday, all good no advisories and passed :grin:
    Looking at the smoke test results and Its clear to see its way below the max permitted but I'm curious if it was good, bad or just normal for a 2.0tdi (PD170) as I've not really a clue what 'zero drift' 'mean value' & 'FPT mean value' are?
    Print out below..
    Edit: also is an idle speed of 880rpm a little high?
  2. Avatar
    snack-media
    Advertisement
  3. SootySport
    SootySport Well-Known Member Team Silver
    3,899
    1,044
    :footy:Does it matter? It passed
    ESD1711 likes this.
  4. SDHA4SLine
    2,613
    523
    Well not really but I am curious about how mine will fair when the MOT's are tightened up. As I understand it the max figure is well above what most modern diesels would ever reach but there are many rumours that in the next year or so things will change regarding smoke test max limits based on your car age and spec. So just wondering if its on the mark or if it should be better than it currently is.
  5. ESD1711
    ESD1711 Active Member
    691
    219
    43
    No idea what they actually mean or what you 'should' be getting - but looking at where you are with regards to what you've gotten and what the max allowed values are - i'd be massively surprised if you had anything to worry about.
    If I remember when I get in from work though - i'll dig out mine from last month for comparison.
    SDHA4SLine likes this.
  6. SootySport
    3,899
    1,044
    If they do tighten up on emissions, then I would have thought it would be for new cars meeting Euro V1. Don't worry about yours.
    Having said that, it is time to ditch DERV's for us mortals, unless you are a taxi driver doing 30k. miles a year, I certainly won't be buying another. The wifes A3 is a pre DPF motor thankfully, still have the egr to clean every year though.
    Cheaper to drive petrol motors now.
  7. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User TDi quattro Audi A4 Audi Avant Owner Group
    7,082
    3,457
    I think the idle speed seems a little high, but only but 20-30 rpm. On EDC15 ECU cars you could alter the idle speed with VCDS adaption on the ECU . Not sure if you can do that on your car.
    The zero drift is I believe a check of the tester. They leave it measuring fresh air rather than the exhaust to make sure that it's reading is stable.
    There are two possible tests, one is an average test and the other is fast pass. Thats what FPT means Fast Pass Test.
    To get past the Fast pass it needs to be less than 1.5 on the first acceleration run which yours was.
    If it exceeds 1.5 on the first run, they do 2 more runs and then average the 3 readings and that needs to be less than 3.0.
    A car has to be really bad to fail a smoke test.
    I found the last MOT for mine and it was 0.69 for a 300bhp plus 3.0 V6 TDI. The wifes 2005 75BHP 1.4 TDI recorded a 0.75 reading.
    So 0.61 is good, no where near a fail.
    http://www.ukmot.com/MOT test/Emissions - Diesel.asp
    Karl.
    mister.c. and SDHA4SLine like this.
  8. gary_a4_quattro
    gary_a4_quattro Active Member Team Meteor Team V6 Audi Avant Owner Group
    596
    188
    43
    I would doubt that, if any maxixmum allowable values were lowered, changed or tightened up, they would be applied to all vehicles. I would imagine they would only be applicable to the very latest generation oil burners. The current values would remain for vehicles of our build years I'm sure
  9. SDHA4SLine
    2,613
    523
    Excellent, very well explained. Thanks Karl
  10. ESD1711
    691
    219
    43
    See, I was kinda convincing myself the other way the other day - but I guess it really depends on what kinda cars you're comparing.
    I noticed the other day that the difference in cost per litre between petrol and diesel was just 3p now. I'd say that in some cases that makes running a diesel car even more beneficial if you're comparing against an older petrol car which is only benefitting from 3p per litre of cheaperness, but costing more in a lack of mpg'ness.
    Compare something like a Mk4 Golf GTi against a GTTDi and its as good a time as ever to be driving a diesel.
    But I can see your point when you look at the 'modern' petrol cars which are capable of getting dieselesque type MPG's out of a fuel which is cheaper.
  11. ESD1711
    691
    219
    43
    For comparisons sake, my numbers were:
    0.02
    0.84
    0.84
  12. Avatar
    snack-media
    Advertisement
  13. SDHA4SLine
    2,613
    523
    Looks similar to mine then
  14. SootySport
    3,899
    1,044
    :smiley:
    If you consider the extra cost of a DERV against a petrol car and the fact that DERV car maintenance is much higher with the introduction of EGR's , dpf's and a turbo charger (especially when they go wrong) then petrol car wins. If you are doing short journeys then the dpf is not doing it's job, it has to go into forced re generation, burning extra fuel to do it's job.
    Some Local Councils are soon to introduce a DERV tax of about £100 a year for the privilege of owning a DERV, Islington being one of them.
    Haven't noticed the narrowing gap between diesel and petrol prices though, maybe it's because of the threat to the future of the DERV they are talking about in the NHS and DOT.
    Maybe time to reverse your conversion to Derv's :smiley:
  15. SDHA4SLine
    2,613
    523
    If I read last years results correctly, rather worryingly my smoke test is 6 times worse than 12 months ago !
  16. desertstorm
    7,082
    3,457
    Have any changes been made to the engine/ exhaust etc since last year ?. 0.1 is pretty low.
  17. SDHA4SLine
    2,613
    523
    Hmm, just a few, most of this was done trying to find the reason why its chucking smoke out.
    Both n75 's
    MAP senser
    MAF sensor
    EGR valve
    coolant temp sensor
    fuel temp sensor
    fuel filter
    air filter
    Inlet manifold actuator.
    Turbocharger
    Coolant thermostat
    Car has had many scans since these parts have been fitted no faults found other than one intermittent egr fault which was cleared and has not come back.
    Having said all this it has now been diagnosed that my car has a "very slight" compression leak (yet to be confirmed if its a inlet or outlet valve or piston rings) so I suppose this could be the reason yes?
  18. SDHA4SLine
    2,613
    523
    Dragging this up from the depths but just to follow up....
    This years mot smoke/opacity (or what ever its called) test attached. Test seems slightly better than last years down from 0.61 to 0.51:grin: Also looks like the maximum permissible Mean value limit has halved from last year???
  19. CoolAsIce
    CoolAsIce 08 CR170 Black Edition S-line owners group Audi A3 Black Edition S tronic
    81
    43
    The limit is 3.00 for cars before July 2008, and 1.50 for cars after this date. 0.6 is average really.
    I find cars smoke more that don't ever get driven hard, generally a quick Italian tune-up down the road clears the smoke.
    Most modern cars with dpf's don't even register on the smoke test at all, we usually end up lightly kicking the machine just to give a reading for a print-out, otherwise it won't give a print out.
  20. SDHA4SLine
    2,613
    523
    So they screwed up on mine then? its a 2006 and the mean limit looks like its a 1.5 limit?
    Not that it matters as its passed but...
  21. CoolAsIce
    81
    43
    Yes they've tested it under the wrong one it seems. But like you say it doesn't really matter as it's passed.
  22. stu-evans
    stu-evans Member
    114
    22
    Your numbers are a lot better than mine..... Mot test last month was 1.41 (they tested mine against 1.50 as well). Car is a 2007 140bhp... Although it is running a non-resonated S4 exhaust set up, so not much to stop the smoke on its way out!.
    I am wondering now whether I should be checking anything on the engine as yours seems so low in comparison??
  23. SDHA4SLine
    2,613
    523
    Probably as you say your exhaust doesn't help matters but I wouldn't be spending money until its a fail (still confused by our being tested at 1.5)
    As for where to look, id say if your car is running nicely and its passing the smoke test then don't worry about it. For this reason I'm reluctant to suggest something for you to look at (that and I have a history of sending people on a wild goose chase :tongueclosed:). Maybe someone like @desertstorm could suggest something for you to investigate (he knows his stuff)
  24. desertstorm
    7,082
    3,457
    As above I wouldn't worry about the smoke test and the absolute readings that you get if your car is running OK and it passed.
    The thing to do is make sure the engine is nice and hot when it's tested and that you have given it a good clear out as well . If the engine is well serviced with a good air filter and no obvious issues it should pass OK.
    I take my cars for a good run to warm them up before taking them for an MOT, I will also do an acceleration run through second and third gear to give them a bit of a clear out.
  25. stu-evans
    stu-evans Member
    114
    22
    Great, thanks both! Car runs great, has far better pull with the S4 exhaust, and is serviced frequently (filters changed ahead of schedule)..... Quite happy to leave it be if there's nothing obvious/easy that may reduce the smoke!
