Hi guys today with @ROB64 we tried to retrofit Cruise control on his 2010 a3 s-line 170 tdi.
So the stalk we used was from pre fl (2005 i guess) a3. Anyway we mounted it, everything went preety straight forward, as car already got MFSW I'm sure it was correct module is fitted.
So I've done coding:
on SW module changed the pre last bit from 1 to 4 so it was looking xxxxx4x (computer and cruise). on engine the "coding 2" - module 11 is not available so used "long coding" module 07, then long coding helper and in byte 4 or 5 instead of 05 (no cruise control) i used scroll menu to select cruise control and changed it automaticly to 25 then confirmed both and done test drive. Result: nothing happen, so checked on SW module and switch on off was working (seen changing value in 1st window on/off) but then tried on road again and tried from using resume, set, +, - and on all nothing. (obviously without touchnig clutch or brake pedal meanwhile).
So my question is: can be stalk faulty or got different pinout on connector?
