Hi all,
I retrofitted cruise control to my car earlier. All installed fine and dandy.
After installing cleared fault codes from VCDS and did the necessaries to enable CC and confirmed it was working on measuring block 004 on the Steering wheel controller (as per a guide on here somewhere).
Took the car for a drive however it didn't work. Luckily I had my laptop with me so could fire VCDS up. I did the cruise control activate login on the engine controller again and then did the full lock left, full lock right, drive 200 yards straight and still no joy.
I opened up meas block 004 on the steering wheel controller and it showed the responses to my input on the cruise control stick fine (as per screenshot attached) however the car wasn't responding (no CC light and not holding speed).
I've ran a scan after with VCDS and it shows a couple errors on the ABS brakes controller which I expect is probs the issue:
2 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 35
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4222
Hex Value: 0x0024
Hex Value: 0x01AB
Hex Value: 0x0001
00493 - ESP-Sensor Unit (G419)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Time Indication: 0
Freeze Frame:
Hex Value: 0x0200
Hex Value: 0x4202
Hex Value: 0x001B
Hex Value: 0x34AC
Hex Value: 0x0001
I can't remember seeing these on a previous scan. Does anyone know how to resolve those or if indeed they are linked?
I've tested everything else on the steering wheel and all works perfectly. There aren't any other fault codes in VCDS.
Thanks in advance
Dave
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 35
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4222
Hex Value: 0x0024
Hex Value: 0x01AB
Hex Value: 0x0001
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Time Indication: 0
Freeze Frame:
Hex Value: 0x0200
Hex Value: 0x4202
Hex Value: 0x001B
Hex Value: 0x34AC
Hex Value: 0x0001
Thanks in advance
Dave
