- Joined
- May 7, 2016
- Messages
- 1,187
- Reaction score
- 222
- Points
- 63
I installed cruise control stalk in my 2006 8P Quattro Sportback, with DIS from factory Board computer - MPG, Avg Fuel consumption , trip.
- I've enabled it in the engine block using the short coding code = '11463'
(it now shows G in the component code so it means it is enabled)
- Also in the steering wheel block = '0000041'
(it's a 1K0 AH Module which fully supports the stalk)
I have:
-manual tranny
-3-Spoke, w/o Tiptronic, w/o Multi-Function
-Board Computer, Cruise Control
-Rear Wiper
= 0000041
Coding
00?xxxx: Transmission 0 = Manual Transmission
00x?xxx: Steering Wheel 0 = 3-Spoke, w/o Tiptronic, w/o Multi-Function
00xx?xx: Tiptronic/Heating 0 = or +1 = Tiptronic on Steering Wheel
00xxx?x: Cruise Control/Board Computer 4 = Board Computer, Cruise Control
00xxxx?: Rear Wiper 1 = With Rear Wiper
I can test it all in the measuring blocks I can see the different bits toggling from 0 to 1 when I move the stalk around in all of the positions but the actual CC isn't working.
The Clutch switch is working because my launch control operates when the clutch is pressed.
Am I missing a parameter in the Instrument Cluster settings or something, I waited 5 mins with ignition off to ensure the values get saved (I am informed all 8P post 07/2005 have the control wire already installed)
This is doing my head . I have VCDS/VAGCOM
Please help, thanks!
I have:
-manual tranny
-Rear Wiper
= 0000041
Coding
