Cruise control & DIS install issues
Leighton82
So i got my mechanic to install a cruise control and DIS stalk into my B7 today and guess what? Neither work. ****** annoying as he didnt test them out before i had to take it away so now i have to take it back. Trouble is im not sure he can do it. He didnt use vagcom and all the online guides look complicated to me. He might have used some laptop based copy maybe? He said he'd thought the code had taken but before i went there i asked about the washer bottle sensor warning and he said there was none (bearing in mind id sent him instructions for this beforehand and said it was definitely required). Can the coding b done without official vagcom?
He also fit new brake pads and a few mins into journey home brake pad light came on and hasnt disappeared! Fun day.
NHN
Site Sponsor
Whereabouts are you located?
NHN
Site Sponsor
I would but economics of travel are against us.
Leighton82
Cheers anyway! I knew i should have got a specialist. Im guessing brake pad warning could b use of cheap pads with questionable sensors. Triple burn with brakes, dis, and cruise issues!
Jon13s
It may well be that you have a steering control module that does not support DIS or cruise control.
Sent from my SM-G965F using Tapatalk
Leighton82
Nah it should b fine. Got this
Jon13s
It's not to do with the steering wheel. It is the module that is bolted to the columm that all the stalks plug into. There's a range of part numbers and all have different combinations if functionality.
Leighton82
Oh. I was told if u had that steering wheel, it was fine. Im sure i saw a guide somewhere that said that. I wasnt going to take it off myself so that's annoying if true. Shouldn't have bothered
LawrenceH
I was under the impression that all modules that support the mfsw also support cruise, so if you have the buttons on the wheel working then you can add cruise.
piglet14
Finally got my midlife crisis car
I read through the entire Cruise thread in the stickies section above before fitting mine.
I'm fairly sure it's in there that if you've got functioning MF wheel then it's CC ready.
Doesn't make it 100% right though.
Leighton82
So ive been let down and now have installed stalks that do naff all. Well wipers work on DIS stalk but yeah, not good. Is there anyone in leeds who can code CC and DIS, and ground pin 1 for me for a reasonable price?
Leighton82
So i took it to some VAG specialists in Leeds and they coded everything. However, it transpires that some **** ebay seller sold me an A6 dis stalk but labelled it as being from an audi a4 avant so the buttons dont work. Very annoying. Can i clarify the exact part number for the dis stalk that will work in a b7 avant? Any help would b greatly appreciated. Also, if anyone has one and wants to sell let me know?
Leighton82
Also, every guide says that washer bottle error is a given but both mechanics ive spoken to say u should b able to code it out without grounding pin 1. Are they ill-informed?
Leighton82
Anyone in Leeds or nearby able to help? Sorry to pester but even just advice around the part number for the dis if nothing else? Other vag specialists want 50 quid just for a diagnostic before doing anything. If it's as simple as just the dis stalk then that would b good to know.
I'm Just Rob.
Moderating or something,
Staff member
Moderator
Gold Supporter
Blurtar
Bring it around here I’m in Leeds, I retrofitted both cruise and Washer level on mine.
Blurtar
Obviously not wanting the help offered then......
