Couple of Sat Nav questions
joinerman Oct 12, 2018
  1. joinerman
    joinerman Well-Known Member
    11,323
    482
    I want to install a sat nav in my B6 but i don't want it up on the dash or glued to the screen, i want to put it in the gap above the ash tray ( slightly angled ) i don't smoke so the ash tray is never used, question one, can i power it from somewhere other than the fag lighter as i use that for another gizmo to play my music through Bluetooth from my phone, question two any recommendations for a unit, prefer a more rectangle shape than a curved edge one so it sits better in the gap, oh & if it has Bluetooth will it conflict with the parrott for my phone.
  2. Avatar
    Google AdSense Advertisement
  3. blackpool1974
    blackpool1974 Member VCDS Map User
    164
    Probably not best practice to be looking down that low whilst driving.
    Cheapest option would be to use your phone if you are wanting audio guidance seeing as its already kicking out sound through bluetooth.
  4. joinerman
    11,323
    482
    Yes but i will use a lot of data on a 4 hour each way journey
  5. blackpool1974
    164
    The majority of phone satnavs download the map to your phone, zero data is used whilst in use
  6. stevey83
    stevey83 Member
    41
    Have you seen where the standard nav plus is!
    DieselJake likes this.
  7. blackpool1974
    164
    Yes, above where he wants to put it
    q5man likes this.
  8. joinerman
    11,323
    482
    Can someone tell me what sat nav apps don't use your data then.
  9. blackpool1974
    164
    Try sygic, will give you 7 days free or navmii which is free all the time
    Both you can download offline maps
  10. stevey83
    stevey83 Member
    41
    Sorry, a few inches must mean a lot to you!
  11. joinerman
    11,323
    482
    Well i have come up with a solution, i downloaded navmii onto my iPhone & made this cradle that the phone just slides into, it works really well
    It is only about 12mm thick so does not sit away from the dash, it does look like it does in the picture but it's tight to the vents.
