Cornering Fogs issues
mk4gtiturbo
I enabled the cornering fogs with Carista but they only work with the indicators and not when I turn the steering.
I have scanned the car and have this:
Central electronics
Part #: 8K0907063C
Coding: 260050914134AF311601000000001D0D4F9D470800010141000000 (hex)
Component: BCM1 1.0
Fault codes:
03110 Control Module for Active Steering, no signal / no communication
03207 Charisma Switch Module
Steering angle
[ECU not present]
The Charisma switch is because I enabled ADS but do not have the dash button.
Do I have a problem or do early cars not have the hardware for this to work? Mine is a March 2009 car.
Neil Wilkinson
I’ve got a 2010 A4, enabled this and it worked ok. Wasn’t too keen on it tho so disabled it. Have you tried clearing the codes?
mk4gtiturbo
I have cleared the codes but I don't know if my car supports different modes for steering. Changing ADS make no difference to feel. My previous car (2014 Octavia vRS) also had different modes and I could feel the difference with that.
jakm15
I activated them on my 60 plate and they work with the steering angle, like you said maybe you don't have the correct module for it to work.
Sent from my moto e5 plus using Tapatalk
mk4gtiturbo
Two things then:
Anyone know where the central electronics control module is located in the car?
and
Can anyone post the part number of there one? Mine is version C
jakm15
Two things then:
and
To be honest I wouldn't go through to much effort to get them working, they make no difference when driving and do look a bit strange when you see them working on the car approaching you.
