Connect the fan directly to the battery temporarily to see if the fan motor is faulty. If the fan runs then it is most likely a duff radiator thermo switch. Other possible causes could be the wiring or a blown fuse.
Does your Aircon work? Mine stopped along with the cooling fans. Took the fuses out from on top of the battery, cleaned the contacts with my shirt and hey presto
