Coolant Warning On Dis Morning Cold Starts?
Omy193
Hi Guys,
I Have a 55 reg Audi A3 TDi S Line DSG
For the past few mornings when i start the car up (cold start) the coolant warning pops up on the DIS and beeps for a couple of minutes and then just goes off?
Doesn't come on again until the next morning when starting cold.
Is it just a sensor problem or something minor?
Thanks in advance guys!
L33AEX
Stupid question but have you checked the level?
or do you park it on a hill?
could be a faulty sensor or your mixture isn't strong enough.
mine used to do this a lot but seems to have stopped since I added neat Coolant.
Omy193
Hi
Sorry should have mentioned in last post, coolant level is fine. Just a tad below max.
And yes car is parked on my drive way overnight which is level ground.
Will try a better mixture, thanks!
It will be the bottle contacts you can see inside the bottle. Either change the bottle or try and clean the fine layer of ***** off the prongs.
