Update on sensor fitting ,prior to fitting the new sensor I noticed that a heavy (ish) foot was needed setting off and it just wasn't as smooth as I thought would be. also sounded like a tractor setting off ..... Also only having the car a week I was not sure what was normal and what was not. I knew I had a niggling issue with temp gauge hitting 90c and then dropping to around 80c and going back so first port of call was a service which I did and then I ordered the sensor and a new thermostat ,the sensor was first to arrive which I fitted pretty quick,i then got a message from Audi to say the thermostat was ready to pick up so a good excuse for a test drive with new sensor in, and I must say setting off was a lot smoother and felt a lot more refined I was convinced a £10 part could not cause such a issue but after 20 miles the gauge was behaving at 90c both when on motorway and off motorway ,I know I need a longer run to prove it's all ok but I could tell going through the gears the car was much smoother ...I do have the thermostat booked in tomorrow so it makes sense to have it done ,as said the proof of the fix is in a longer drive but my gut feeling after the first drive after fitting is positive ...
