Considering an RS4 b7
gray99y
Any general problem I should look gorgeous with one of these?
Sent from my SGP621 using Tapatalk
RS4 Cookie
Hi mate, in general the B7's are sound motors. The DRC suspension is great if you get a good one, check for any oil leaks on the Damper units and any related pipework, they're not hard to replace but can be pretty costly, I replaced mine with a set of Bilstein coilovers due to a suspension pipe leaking right above the fuel tank. The Oil cooler lines are prone to leaking, approx. £120 for the shorter line and approx. £170 for longer one...not too expensive but can be a real pain to do especially getting the nuts off the Oil cooler. And last but not least...Brake discs, the newer, the better, again not a hard job to do but ****** Expensive..Approx. £1200-£1400 for the four then another £400-£500 for pads from Audi. Euro car parts can do a full set of pads for about £150. Good luck..
