- Joined
- Oct 2, 2015
- Messages
- 3,565
- Reaction score
- 770
- Points
- 113
Hi,
I have a leak down test kit I hadn't got around to using but I got a compression test kit the other day which I will use first.
my plans are to try dry and then wet - the instructions are a little Chinese to me, it explains what the signs may mean. my plan is to do this first and then if one or two cylinder's are playing up use next door's compressor and perform a real leak down to try and identify the fault(s).
is there a quick reference guide for this.
My plan was
1. to remove the fuel pump fuse and unplug coils
2. only remove one spark plug at a time (photo)
3. check dry to see whether the pressure increases or stays the same (valves?) turn engine over for 5 secs?
4. only if too low in 3 - check wet to see if the pressure is much higher than dry (rings?) - turn engine over for 5 secs?
5. replace plug
6. repeat for next cylinder
Any hints - is this wrong dangerous etc
My plan was
5. replace plug
