Need to do a compression check - something isn't quite right and need to fix before I move it on.
Compression kits seem fairly cheap - Sealey CT955 is only £25 ish.
Guessing I will need to remove the coil packs both sides (V6) and remove the fuel pump fuse. Then get cranking ?
If anyone has the compression readings to hand that would be appreciated.
Cheers.
Cheers.
