Companies who can tune out wastegate rattle
porkopops
I'm not having much luck finding anyone in/near Hampshire that can help with tuning out wastegate rattle that is now ever more evident since I went full de-cat. (2017 FL)
Does anyone on here know of a company near Hampshire that can do this?
Paul
D0C
Got to be worth the trip to MRC? Only about an hour and 20 mins or so away from you.
Boj27
Active Member
Went stage 2 mrc today. WG rattle has 90% gone. Was advised there is a patch coming out in the coming weeks so it’ll be 100% gone.
Aoon_M
We have had this patch available since late 2019, through software you can get rid of around 90% of the noise but will still be present very slightly. I don't see it being possible to get rid of this noise 100% as the waste gate still needs to open at some point.
Only solutions I have seen to get rid of this completely so far are by fitting a big turbo kit or a TTE777 hybrid turbocharger as they port the waste gate arm, combined with a waste gate rattle patch it eliminates 100% of the rattle.
Something some of my other customers have been doing is fitting RS3 8v pre fl Secondary catalyst pipes. This works well, gets rid of the Decat fumes but kills a little noise.
porkopops
Thanks @Doc @Boj27 @Aoon_M
I'm thinking of speaking to MRC to fix the wastegate rattle (or partially, it seems) and uprate the brakes at the same time. I may even ask them to dyno it as the last dyno was on one of the very hot days and power was down.
