  2. Dismiss Notice
Colour screen mod for cluster
b1ackh3art Feb 20, 2017
  1. hydro s3
    hydro s3 S3 amk
    1,363
    410
    Yes mate I saw it on fb. Looks good with all the new gauges on it. I'm looking forward to getting this installed.
  2. Avatar
    snack-media
    Advertisement
  3. <tuffty/>
    <tuffty/> Badger 5 Edition...Its all about the flow... Staff Member Moderator
    24,362
    5,601
    After all the messing about with LED's I stumbled on a video of the MFA fitted to an S4 cluster which is the same illumination setup as the S3... actually doesn't look too bad...
    Tj 0785 and S3AMJ like this.
  4. S3AMJ
    S3AMJ OEM+
    2,198
    786
    Your right, not bad at all! The white needles are what make it work with the “S” clusters. I’m still undecided....
  5. Tj 0785
    Tj 0785 Registered User Bronze Supporter Silver Supporter VCDS Map User
    3,877
    1,185
    Yeah I thought it looked good when I had it and you couldn’t tell it wasn’t a oem screen that’s why I wasn’t fused about finding a new cluster option since the a6 One went out the window which I got my money back for today
  6. syncro
    syncro Registered User
    230
    79
    F2FB0682-6CF0-4063-AA2A-429F6E4FD278.jpeg Someone posted this picture on mk4 cluster mods Facebook page, white characters do match the colour mfa very well.
    S3AMJ likes this.
  7. IPG
    IPG Registered User
    1,847
    784
    No movement or updates yet but some sets look like they're already shipping
    Will install the new firmware in a few and link a video :D
    S3AMJ likes this.
  8. syncro
    230
    79
    Does anyone have access to the wiring diagrams for the 8L S3 instrument cluster plugs? And for the mk 20 abs unit plug?
  9. warren9022
    warren9022 Registered User
    470
    224
    43
  10. syncro
    230
    79
    Thanks that helps, so blue plug pin 32 is esp/tcs
    I have s3 clocks back in mine so I could compare with the a6 ones and I needed to do the basic setting of my steering angle sensor since I changed it.
    When I open the bonnet on my s3 and on my pd130 a3 neither are showing it open in the dis screen but the doors and bootlid show when opened, could someone check if the dis should display open bonnet?
  11. warren9022
    470
    224
    43
    Pretty sure my bonnet doesn’t show as open on the DIS but will check for you next time I go out to the car :thumbs up:
  12. Avatar
    snack-media
    Advertisement
  13. IPG
    IPG Registered User
    1,847
    784
    OEM scren doesn't show bonnet open, but the sensor IS present
    colourmfa shows bonnet open
    syncro and warren9022 like this.
  14. Tj 0785
    3,877
    1,185
    Have you received your batch yet do I need to be sending my cluster over anytime soon need to get my **** in gear and get the wiring installed for the mfsw,mine has to be the longest ever mfsw install ha
  15. warren9022
    470
    224
    43
    Nothing wrong with taking your time mate :tearsofjoy:
  16. Tj 0785
    3,877
    1,185
    I think I fitted my mfsw in like June last year people have done full restoration in the time it’s taken me to do this haha
    IPG likes this.
  17. IPG
    IPG Registered User
    1,847
    784
    Looks like larger orders are getting held back.... not sure why
  18. S3AMJ
    S3AMJ OEM+
    2,198
    786
    Haha yeah but dude, you were doing it before anyone else and working it out as you go along. We all had “very” good instructions and a shopping list. I wouldn’t have even entertained the idea hadn’t it been for these boys.
  19. Tj 0785
    3,877
    1,185
    I’m in no rush just a thought
    What puts me off doing it is everytime I go out to the car I’ve got to climb through the boot,for some strange reason the outside door handle stoped working after I parked it up hopefully get a few jobs done on it tomorrow door handle being one of them
  20. warren9022
    470
    224
    43
    Does seem a bit weird, you'd think they'd get the bigger orders out the door first....
  21. warren9022
    470
    224
    43
    Get the door handle fixed and the MFSW is pretty straight forward, if anything I over complicated it in my guide. Need any help just give me a shout :thumbs up:
  22. Tj 0785
    3,877
    1,185
    The guides been a life saver couldn’t of done it without it, I’ve done most of it just have to connect the wires to slip ring and connect to the power and whilst it all out run a gala wire for the sat nav that I never done then fit the rear camera setup and get that working
  23. warren9022
    470
    224
    43
    If you haven't already bought a reverse camera I've found one that I'm going to replace mine with, it allows you to offset the image left or right (as where I've mounted mine is off centre to the car). So the image appears on the RNSE as if it's centrally mounted.
  24. S3AMJ
    S3AMJ OEM+
    2,198
    786
    Where have you mounted it Warren? I was thinking of doing something similar by removing one of the electric boot opening switches which has failed.
  25. Tj 0785
    3,877
    1,185
    I have one but not fussed about getting another before I drill the boot as it was only a few quid, you got a link?
  26. warren9022
    470
    224
    43
    I combined mine with an LED number plate light...… (excuse the paintwork, respray next year :sweatsmile:)
    There isn't any adjustment in height or left/right view on it though so I've never been happy with it.
    The new one should allow me to position it exactly where I want it.....
    https://www.aliexpress.com/item/PAR...lgo_pvid=64332252-17bd-4431-9d0a-5a0633080af5
  27. S3AMJ
    S3AMJ OEM+
    2,198
    786
    Looks smart, I have seen the LED number plate light cameras available for the 8P, nice to see you’ve got one working on the 8L. I might see how difficult it’ll be to mount one in place of my failed boot switch. So it’s slight more central, but with the option to adjust it is a big bonus :) cheers mate
  28. warren9022
    470
    224
    43
    No worries mate, I might do a write up on it when I fit the new one in case anyone else is interested in doing it.
  29. IPG
    IPG Registered User
    1,847
    784
    S3AMJ, warren9022 and <tuffty/> like this.
  30. warren9022
    470
    224
    43
    @IanPG Have you had a play with the new animated boot screen yet in the latest firmware release?
  31. IPG
    IPG Registered User
    1,847
    784
    Not yet sorry ... have been pushing on with rebuild.
    Ps. I finally got the tracking. All are on the way.
  32. IPG
    IPG Registered User
    1,847
    784
    For those involved. I have a tracking number.
  33. Avatar
    snack-media
    Advertisement
  34. <tuffty/>
    24,362
    5,601
    From Russia (with a quick stop off in Aus) with love.....
    ....and so it begins :)
    ToughlilT, Rainbird, S3AMJ and 2 others like this.
  35. syncro
    230
    79
    Are you doing a diy install?
  36. <tuffty/>
    24,362
    5,601
    Yarp
  37. <tuffty/>
    24,362
    5,601
    Spent a couple of hours last night making a start... I won't go into loads of detail as there are instructions online to fit these and Ian has done a pretty comprehensive write up here..
    https://www.audi-sport.net/xf/threads/not-another-nogaro.278975/page-4#post-2937562
    A few pics of progress so far
    The supplied wire doesn't strip very nicely but I am still an old skool use side cutters guy which doesn't help on thin wire like this lol..
    The holes are sooooo close together though... good job I have needle tip bits!
    sami ramazanoglu, IPG, syncro and 3 others like this.
  38. IPG
    IPG Registered User
    1,847
    784
  39. <tuffty/>
    24,362
    5,601
    Nearly...
    Quick powerup test after double checking connections... need to test in the car then cable management and button it all up :)
  40. S3AMJ
    S3AMJ OEM+
    2,198
    786
    Quick work @<tuffty/> :D
  41. Ian W
    Ian W Registered User
    1,160
    85
    That looks great.
    Sent from my ONEPLUS A6003 using Tapatalk
  42. <tuffty/>
    24,362
    5,601
    Done...
    I haven't used the matt screen protector at this time (as I forgot) but will see if the glare is bad enough to warrant me fitting it... the extra contrast afforded by the glossy screen will help my crappy eyes at least :)
    ToughlilT, syncro, S3AMJ and 3 others like this.
  43. Bluepower
    Bluepower Registered User
    269
    79
    That is soooo sweet!!!
