Collected and less than 24hrs later......
djjuk Dec 13, 2017
  1. djjuk
    djjuk New Member Team Mythos TFSI Owners Group Audi A4 Audi Avant Owner Group S-line owners group
    24
    21
    It is back with Audi after eating it's gearbox.......new A4 Avant SLine 2.0 TFSI STronic.
    Not the best of starts but these things happen. Audi assistance and the dealership I kangaroo hopped into this morning were first class and I now have a 17 A5 until mine is fixed. Parts on back order from Germany so not expected back until the new year.
    Was nice for those few hours I had it though!
  2. Avatar
    Google AdSense Advertisement
  3. cuke2u
    cuke2u Well-Known Member TFSI Owners Group saloon Audi A4 S-line owners group
    10,650
    4,083
    Bad, mine broke after only 1300 miles, what is the issue with yours?
  4. djjuk
    24
    21
    Mine was less than 100 miles. Not good that there seems to be a few of these failures now.
    Stalls, not able to find a gear, numerous error messages and remaining in 6th / 7th gear when slowing for roundabouts etc and then seeming unable to go down the box so it would just give up. Kangaroo hopping at low speed as could not find a gear. No reverse etc etc.
  5. cuke2u
    10,650
    4,083
    Jeez not good at all and you must be gutted. Mine just refused to select a gear with a message that there was gearbox malfuction. Luckily this occurred outside our house not on the holiday we'd just arrived back from.
    Turned out the parking solenoid had failed locking it on.
  6. djjuk
    24
    21
    Yes a bit gutted but remaining philosophical about it...as what else can you do?! Wish it was just a solenoid but I got the impression from the master tech today that it is more 'terminal' than that. Ah well - we shall see I guess.
  7. Gazwould
    Gazwould Well-Known Member
    6,595
    2,697
    S-Chronic.
  8. Gary_LB
    Gary_LB Active Member Team Manhattan Team V6 Audi S4 Black Edition quattro
    146
    125
    43
    Sorry to hear this. Let’s hope Audi look after you well and it doesn’t taint your experience too badly
  9. cuke2u
    10,650
    4,083
    Yes I was also philosophical as, after all, it wasn't the complexity that killed my gearbox but a £25 solenoid. Once they'd identified the issue the repair was quite quick. I just hope yours is...
  10. BarryG79
    BarryG79 Well-Known Member
    1,171
    2,270
    Gutted for you mate, mine went on the S3 at 7k miles back in August. From what you describe it sounds very similar although mine also sprayed gearbox oil all over the place. Replacement box and mechatronic unit was required. Hopefully you have a good dealer that will take care of you.
  11. NickGun
    NickGun Active Member Team V6 TDi Audi A4 Audi Avant Owner Group quattro S tronic
    265
    150
    43
    Truly gutting :fearscream:and not a great start to say the least, fingers crossed its sorted quickly and with minimum fuss for you, then you can get on with enjoying the car - as you say best to be philosophical but not always that simple eh.
    We've just ticked over to 18k miles on our B9 S-Tronic and thankfully have had zero gearbox issues like most on here.
  12. Avatar
  13. djjuk
    24
    21
    Mechatronics unit replaced. Another gearbox fault now found whilst they did this. More replacement parts back ordered from Germany......the wait continues.
    BarryG79 likes this.
  14. cuke2u
    10,650
    4,083
    Seems like they just should have replaced the whole gearbox but they'd bulk at the cost...
  15. BarryG79
    1,171
    2,270
    Dealer billed £4.5k to Audi as a warranty claim for my gearbox replacement, said it would have cost £6k for me to replace
  16. BarryG79
    1,171
    2,270
    Just make sure that when you get it back, the gear selector has been adjusted correctly. Mine showed as being in park but it wasn’t actually, meant that car didn’t hold when in P and handbrake not on. Was overlooked by dealer as it wasn’t something they would expect to check normally.
  17. djjuk
    24
    21
    Seems like that may end up being the (delayed) outcome at this rate.
    Cheers. Will do.
  18. djjuk
    24
    21
    New valve body now fitted, following the new mechatronics unit. New problem is that the car will not accept the basic settings required.....much scratching of heads and Audi technical involved....
    A month on Saturday since it arrived (and left). Rejection is almost there. Bored now.
  19. Syed Shah
    Syed Shah Cars are a mans best friend, then dogs..
    430
    193
    43
    I would pile the pressure if i were you honestly. If you’re paying monthly for the car it should be refunded as you didnt recieve a good or fit for use product from Audi..
  20. cuke2u
    10,650
    4,083
    Quite, unfit for the purpose...
  21. djjuk
    24
    21
    Agreed. It's a company/lease car so have handed it over to them to sort. Replace (same spec) or new order.
    Syed Shah likes this.
  22. Syed Shah
    430
    193
    43
    Defo. Put the pressure on as end of the day you’re paying for a car that you’ve spent barely a few hours in out of no fault of your own.
  23. djjuk
    24
    21
    And it is back.....collected yesterday so we start again on a hopefully more positive journey. 300 ish miles since I picked it back up and touch wood all seems fine, tried every gearbox parameter I could think of and no problems so far.
    Still has the new car smell as well - so I am pretending the last few weeks did not happen and my new car (actually) arrived yesterday.
    Hopefully my last post on this thread.
    Sandra and BarryG79 like this.
  24. cuke2u
    10,650
    4,083
    Fingers crossed for you, like myself I am sure it'll take a bit of time for you to regain your confidence with the gearbox...
  25. djjuk
    24
    21
    Cheers, so far so good!
    rasA4, Jcbmally and cuke2u like this.
  26. france71
    france71 Active Member
    126
    78
    I thought the new S-tronics were sorted out these days? Or am I mistaken?
    Did Audi give you any compensation for this unpleasant start of car ownership?
    Hopefully happier motoring from now on...
  27. cuke2u
    10,650
    4,083
    I doubt if any monetary compensation can be obtained at all, cars break down even when new. The compensation is you don't have to pay for the repairs...
  28. djjuk
    24
    21
    And back it goes again...
    70 on a motorway, big warning sign pops up for engine fault "Do not exceed 1000rpm and get to workshop" pulled over and got to press the SOS button. Nice fella turns up in his van and plugs in a laptop. Yes, he says it is giving me a code for an engine fault that requires recovery to Audi. Nothing I can do here.
    2 hours later a low loader turns up, up I climb and and off we trundle to nearest Audi garage. Can't have a look until 9th May the pleasant service lady tells me. Rather busy with service work currently. Explain politely my previous gearbox 'issues' and the less than stellar reliability to date. Very apologetic service manager. Please help yourself to a complimentary coffee from the machine.
    Audi have now provided me a Vauxhall Insignia through Enterprise whilst I wait. I query a 'like for like' replacement option. Sorry I am told. Audi only authorise this class of vehicle to be given.
    All a bit rubbish really. Can't say I have been blown away by my Audi experience to date. Ho hum..
  29. BarryG79
    1,171
    2,270
    Audi dealer told me that if car is recovered by Audi Assist to them, they then have 48hrs in which to diagnose fault. I would be waiting that long for it to be looked at. If garage not playing ball contact Audi direct.
    Re the Insignia, is that what enterprise told u?
    Contact the team that deal with the hire cars at Audi ‭01908 467500‬. I requested like for like at 4pm, they organised a taxi home (15 miles) from dealer, they had no cars either. Then a taxi to work the next day, another 15 miles. By 10am a 4K mile S3 was delivered to the office. All that without being pushy or demanding.
    Good luck.
    mister.c. likes this.
  30. ScottishA4B9
    ScottishA4B9 Well-Known Member Team Daytona TDi saloon Audi A4 S-line owners group Manual
    3,400
    997
    @djjuk You have grounds to reject the car and that is what I would be doing. Sounds like you have a ‘bad’ one.
    These auto gearbox issues seem to be all to common with Audi’s. This is playing on my mind as I consider a new S4.
  31. cuke2u
    10,650
    4,083
    The S4 has a completely different gearbox to the 4 cylinder petrol engines...
    rasA4 and Spaceman_RS3 like this.
  32. Spaceman_RS3
    Spaceman_RS3 Well-Known Member Team Ibis Team Panther Audi S4 Audi RS3 Audi Avant Owner Group
    1,456
    841
    There only common because we’re in a concentrated place the actually percentage over all them sold will be tiny.
  33. Avatar
  34. djjuk
    24
    21
    Thanks all. Slightly complicated in that it is a company car through LEX so having to go through various people to get anywhere. Will update on any change.
  35. Syed Shah
    430
    193
    43
    Ridiculous! and then to put you in a vauxhall insignia is just a double whammy... I would honestly start finding out what your rights are as a consumer of a good that is not fit for purpose (evidently).
  36. q5man
    q5man Mythos Appreciator Team Mythos TFSI Owners Group Gold Supporter quattro Audi Q5
    3,694
    4,283
    agree with this, as many moons ago when I had an issue with allroad, was advised it is best to speak to audi assist, as get much higher priority than just going straight to dealer...what a nightmare :weary:
  37. djjuk
    24
    21
    And it is back - ECU was replaced. Audi UK were as helpful as they could be to be fair in the end. Frustrating none the less.
    3rd time lucky I hope :racer:
    WesT-gefül and q5man like this.
  38. q5man
    3,694
    4,283
    Fingers crossed all sorted now, 3rd time lucky as you say :thumbs up:
    Spaceman_RS3 likes this.
  39. cuke2u
    10,650
    4,083
    Yes hopefully, you have the patience of a saint....
    q5man and WesT-gefül like this.
