Cold start problems
Tony77 Sep 4, 2018
  1. Tony77
    Tony77 Member
    155
    Hi guys I'm back again I was off cause i was fiting my new setup .. but now im with an issue I wounder if u guys can help . Cold start problems in the morning it never starts first time changed crank sensor still same tried changing fuel same again any ideas please
  2. Avatar
    Google AdSense Advertisement
  3. S3 Hilife
    S3 Hilife It's an addiction Team Dolphin Grey VCDS Map User Gold Supporter Audi S3 quattro
    969
    587
    93
    Have you scanned for faults with VCDS? Also try disconnecting MAF sensor and also check temperature of CTS is reading correct with VCDS
    Steve
    Tony77 likes this.
  4. Tony77
    Tony77 Member
    155
    Yes bro nothing comes up but i will try to disconnect the maf and see what happens from there cts is new ..cheers even spark plugs was changed
  5. <tuffty/>
    23,191
    4,866
    Might help if you gave a bit more information on the 'new setup' in case there is a hardware change contributing to the problem... can only diagnose based on assumption of a standard car...
  6. Tony77
    Tony77 Member
    155
    Tdo5 20g hybrid 640cc injectors. [​IMG]
  7. <tuffty/>
    23,191
    4,866
    First obvious question... is it mapped for this new setup yet?
    Tony77 likes this.
  8. Tony77
    Tony77 Member
    155
    Yes with 407bhp... will try and start it with Maf unplugged and see what happens
  9. <tuffty/>
    23,191
    4,866
    has it never started properly or just started doing this?
  10. Tony77
    Tony77 Member
    155
    Just on this engine but my old engine never had this issue ... my previous engine I snapped a rod so so this one but since I fitted this one been having this problem and i have no idea what to do now ‍♂️‍♂️‍♂️‍♂️
  11. S3 Hilife
    969
    587
    93
    So it started doing it straight after swapping the engine? but ran fine with the old engine after your hardware upgrades or was all that done when the engine was swapped?
    Tony77 likes this.
  12. Avatar
  13. Tony77
    Tony77 Member
    155
    No man we just swaped the engine everything else was and still is same I reackon it's some kind of sensor or maf it can't be the fuel man I dont think anyways
  14. Tony77
    Tony77 Member
    155
    Just unplugged the maf still same
  15. <tuffty/>
    23,191
    4,866
    so it was mapped on the previous engine and you built a new one to the same spec with rods?
    Have you had a smoke test for leaks?
  16. Tony77
    Tony77 Member
    155
    Yes it was ... rods still the original ones .. And no smoke tests
  17. S3AMJ
    S3AMJ OEM+ Team Brilliant Black Audi S3
    1,110
    301
    Let me get this right, you’ve not upgraded the rods on the new engine that you’ve swapped everything over too? And the reason why your old engine failed was because you bent a rod?
  18. Tony77
    Tony77 Member
    155
    He'll no I bent a rod cause of the ko4
  19. S3AMJ
    1,110
    301
    Ahhh right, ok. So this engine is forged then. Ok. Best thing to do is scan with VCDS. Could be a multitude of things, like others have mentioned, faulty MAF, vacuum leak, etc.
  20. Tony77
    Tony77 Member
    155
    Thanks boys
