coilovers on
marknjayne
nottinghamshire
what do you think,another 10mm lower,just seems slightly high still
Reactions: Paullie
spacers will come (going for 8mm rear and 5 mm front),just think it should be a little lower,will give it over the weekend to settle,may gain another 5mm once settled
I think it looks really good at the moment and as you say, you may get another 5mm when they settle. Very smart indeedy! :wub: xx
That looks like its at s-line height. Slightly higher maybe!
You sure they actually fitted the coilovers? ;)
Yeh deffo lower than the standard s-line setup , I think the rear is of too bad but I want to take the front down a bit more
Theres no way that's S line height on a 3.2....I can vouch for that.
Looks about right to me Mark, any lower and there may be the occasional rubbing
From the photo it looks like s-line height to me. Or there abouts.
Doesn't look "lowered" at all.
It does need to go down a bit more IMO , I have a pic somewhere of my car on standard s-line suspension to compare but I'm away from home tonight so will do it tomorrow ;)
this is standard 3.2 s line height, from a similar angle. It does look slightly lower, and like you say it should settle too.
Mines getting the works tomorrow, it hasn't been washed in over a month. And for the o.p, if you haven't had to remove 'The' screw, it's too high!
104
8K
13
6K
993
N8
