Coilovers on budget for S3 JOM's or Stance+ ?
Black
Hi guys,
Now the car is sorted and running as it should, I'd like to give it a bit character.
I was thinking about lowering springs, however to shocks are leaking so it's pointless.
I don't want to spend fortune on them to be fair, I had JOM's on my previous 3.2 V6 A3 and they seemed okay. Any advice what's better for the S3 8L 2002, do I need any extra kit to get the camber sorted after lowering it? Lets call it a budget of £300.
Thanks in advance.
Pat
Sent from my SM-G950F using Tapatalk
Solberg
Dont TA-Technix have coilovers for around 200 pounds? :)
There is no adjustment for camber on the rear so you need adjustable tie arms like mentioned above. I have the ones from Forge, but they are rather expensive. Check out have they have on www.awesomegti.com for example.
Black
As mentioned you will also need adjustable tie bars but the JOM and Stance+ kits are basically the same kit, just a different colour.
Damian @ DPM Performance
Hi buddy,
I'm going to order mine next friday. On the other hand have you got any Jom's for a W8 passat 5.5 ?
DPM
Site Sponsor
Site Sponsor
Hi buddy,
Can you confirm the registration and we will check for you?
Black
BC05 PXR it's an import so might struggle.
It's a passat estate 4WD W8 2005 4.0.
Black
Unfortunately JOM don't do a kit for the 2005 Passat W8 model.
Any other reasonably priced coilovers for that passat ?
