- Joined
- Sep 14, 2015
- Messages
- 108
- Reaction score
- 75
- Points
- 28
Thanks for the update Do you think that the clutch pedal has got softer, or did you just get used to it?
I had no idea that wheel alignment will need to be done afterwards. Thanks for the heads up!
yeah has defo got softer! so much more feel through pedal also. yeah alignment needs to be done as subframe needs to be dropped or removed to get gearbox out of car. which is why I fitted springs at same time. and on the subject of springs drives soo much better its more stable at high speed, doesn't bounce around as much, is more comfortable and sits like it should of when it came out of factory!!!! only downside with as with most lowered cars in can crash a bit into the unexpected large potholes
agree with you on the springs , my eibachs are great , improved ride all round no crashiness at all but eibach dont drop as low as h&r
Did you replace the release bearing and flywheel at the same time? Got a quote from AMDTuning in Essex yesterday to have the Sachs clutch fitted, and they recommended replacing those two items at the same time for £349.
How do the springs work with the adaptive dampers?
How much did AMD quote you for a Sachs clutch fitted if you don't mind me asking?
