  2. Dismiss Notice
Clutch problem
Filledille Nov 1, 2020
  1. Filledille
    Filledille New Member
    The car is an Audi A4 B8 with 3.0 TDI engine and its having about 230000km on it.
    Hello, a couple days ago my clutch started to get stuck like half way on the way up while driving, it wasn’t often so I was able to get home. When it got stuck it popped up by itself and sometime I had to tap it with my foot to get it to pop up again.
    When I got home I wanted to investigate the problem so I started to push the clutch to see if and where it sticks. And after a couple of pushes it suddenly got hard and I could only push it half way down then it gets too hard to push in. After having it only going half way down I pushed it harder and eventually the arm between the clutch pedal and the master cylinder got bent and fell off from the master cylinder.
    The day after that did I take the arm off and bent it back and pushed it in place again but the clutch still only gets half way down. I’ve done some googling but no one seems to have the same problem but I can guess that it’s the master or slave cylinder.
    The car is in my driveway and I’m no mechanic or anything so I’m not able to do that much by myself unfortunately.
    I hope someone can help me with my problem!
    In best regards Filip.
  2. Avatar
    snack-media
    Advertisement
  3. Simon
    Simon Registered User
    376
    122
    43
    Sounds like a problem with the release bearing and arm, gearbox off job to fix that afaik
  4. Filledille
    Damn okay thanks for replying
  5. Gooders
    Gooders Active Member VCDS Map User
    295
    74
    Did you find out the fault ?
    Filledille likes this.
  6. Filledille
    No nothing yet.
  7. Filledille
    Update, today i tried to start the car and pedal got to the floor and got stuck there and it started to leak from master cylinder so i will change that and ser.
    audiwaterpump likes this.
Tags:
