Clutch pedal
Feza
Clutch pedal sticking intermittently having to lift clutch pedal up occasionally when unable to select gear car tried to drive with clutch pedal flat down ?
Feza
Well eventually had to have a new clutch kit fitted due to the release bearing being faulty it was sticking on the input shaft and had a new clutch servo fitted to for peice of mind as the clutch fork wasn’t coming back into the correct position causing the clutch pedal not to return occasionally
