Hi pretty new to all the audi stuff....I have a problem with my current cluster, the fuel gauge is not working good..it's definitely a cluster problem, i got a new one from a junkyard how can I program it to work well on my car?
You need to eprom from your original cluster via some software. I can’t remember what it was now. @Tuffty might be able to help there. It’ll also copy over your immobiliser info. Use with caution though because you can potentially brick the cluster. What car is it an A3 8L or S3 8L? Sent from my iPhone using Tapatalk
Firstly have you checked the cluster via vcds needle sweep etc to rule any other issues have you scanned for fault codes? You will need to look at this page also http://wiki.ross-tech.com/wiki/index.php/Immobilizer_III_Key_Matching_(Cluster)
