Cloud of dirty smoke starting up
Tdibooster Oct 28, 2018
  1. Tdibooster
    Tdibooster Member
    51
    First thing in morning I get a cloud of dirty smoke (not blue) from my 3.0 tdi
    Is this indicative of failing injectors or pump? No codes apart from left engine mount. Had 2 bad glowplugs but replaced them.
    Did have a maf code other day but hasn't returned.
    Are there any pump pressure or injector figures to compare?
    On blocks for injectors only 1 seems a bit low .47mg.
    Cheers guys.
  2. Avatar
    Google AdSense Advertisement
  3. joinerman
    joinerman Well-Known Member
    11,175
    462
    Sounds like a dribbling injector -s , when you fire it up it's burning the diesel off.
    Tdibooster likes this.
  4. Tdibooster
    Tdibooster Member
    51
    1 injector is a bit off just out of spec so could be that 1
    Just realised I have failing maf so ordered new oem 1 for tomorrow. See how it goes after replacing it.
    Was out tonight and have a fair reek. Have a feeling it's maf related obviously giving wrong air flow numbers. Especially since the fault was for low circuit air flow. Hope it's this anyway
  5. Tdibooster
    Tdibooster Member
    51
    Well new maf fitted. Boosting better but still have dirty cloud when flooring it.
    Does anyone know the numbers for leak off testing injectors ie:ml per minute at idle etc?
    Also wondering what pump pressure etc should be also.
    Car gets new engine mount at audi Thursday. Wonder if they'd do leak off test at same time?
  6. joinerman
    11,175
    462
    Most oil burners leave a cloud when you floor it, mine does.
  7. Tdibooster
    Tdibooster Member
    51
    Nah they don't I've had 270bhp mk1 octavias.300bhp golf tdi etc and none threw a reek like this. It's unburnt fuel. But WHY. A good engine,turbo etc shouldn't leave a cloud . Possibilities? Egr,turbo,injectors,boost leak,temp sensor etc. Normally it's 1 of those but this v6 stuff is new to me lol
  8. Tdibooster
    Tdibooster Member
    51
    Just took car for a spin then plugged it into vcds.
    When I thought I had 1 injector underfuelling at times its the exact opposite. All are slightly under BUT my number 4 injector is 1.6mg!!!
    Think it's knackered lol. But is it not that's bad or is it compensating for an injector that's not right just before firing order of inj not? Surely someone must know. Cheers
