My car originally had adaptation channel 19 as 0 , which is no radio clock, measuring block 2 data window 2 was showing TEST OFF , measuring block 11 window 4 was showing 0. MVB 11 window 4 is just to show what is in adaptation channel 19, ie radio clock sync interval setting.
Then I changed channel 19 to 1 , the value you set is the interval at which the radio clock will sync with DCF-77 signal, the value can be 1-50 min. I was already in the time menu in MMI when I changed adaptation in module 17 (ins.cluster), the Time source menu appeared automatically.
Then I viewed measuring block 2 again and it now changed to
Receiver N.ok , no DTC's were recorded in module 17 for lack of radio receiver. I did then lock car and unlock and repeat scans and no DTC's, so only way to see fault or lack of radio receiver without visual checks is MVB 2 data window 2 in module 17.
Here is a video of me doing some stuff in VCDS
Near end of video you'll see I did an output test in module 17 and there was no lamp/indicator for radio wave that came on. I've noted now after viewing video there is a segment test, that maybe the one to do when you read on and see info below.
I then looked at owners quick ref card, Link:-
http://www.vaglinks.com/docs/audi/quickreference/audi.co.uk_audi_a6_c6_quickreferenceguide.pdf
Page 5 had no info, then on page 8 I noticed a blurry logo by the clock, further googling revealed this great thread Link:-
http://forum.a8parts.co.uk/showthread.php?t=6843
So do you get a logo like in A8 thread rich? I don't when coding radio wave clock in, I think it only comes on when successful sync or if you have the radio wave receiver and as my ins.cluster detecting lack of receiver in my car no logo mate.
I will try the segment test in cluster to see if logo appear and report back
, I've also left car in radio clock mode and synced my watch to it see what goes on
