Climate control update
S3AMJ Oct 24, 2018
  1. S3AMJ
    S3AMJ OEM+ Team Brilliant Black Audi S3
    1,113
    301
    Evening All,
    So as most of us are undergoing interior updates for our cars, the RNS-E, Multifunction Steering Wheels and alike. There is one thing I’d like to change, the climate control. Now mine isn’t in bad condition at all for a soul black one. But I’ve search around all the Audi car models and this is the closest I could find to a match, size wise and connectings.
    This is the current one we find in the facelift S3 8L’s with heated seats
    Take note of it’s size and connections, 4 block connectors with several pins and a 2 pin connector which I’ll assume is its power.
    Now below is from an Audi A6 C6
    [​IMG][​IMG][​IMG]
    Looks the business, nice small chrome accents and to top this off you can replace the RNS-E dial knobs for the same style! To make it match and look like a 3G MMI RNS-E.
    Same number of connections but obviously a different style block, some re-pinning and I think that would work.
    Any thoughts?
    Ash
  2. Avatar
    Google AdSense Advertisement
  3. AmanDosangh
    AmanDosangh Member
    67
    Following.
    S3AMJ likes this.
  4. imz
    imz Member
    345
    17
    Would be awesome if it can be made to work. Will be checking daily for updates
    S3AMJ likes this.
  5. <tuffty/>
    23,195
    4,866
    Not sure how the dual zoning would work... I assume that the cars its from have extra flaps and motors to be able to control temps each side... I doubt the 8L will have that although I guess it maybe possible to wire just 'half' of it and have the other half for show...
    Only other potential issue is comms... later cars being canbus and the 8L being k-line... dunno what issues might arise from that as the aircon unit takes data from sensors dotted about the car which would most likely be k-line...
    Be interesting though if it does actually work... best of british ;)
    S3AMJ likes this.
  6. S3AMJ
    1,113
    301
    We are determined to make the interior of our cars Frankenstein’s. A4 RNS-E, S3 8P gear knob, A5 multifunction steering wheel, S3 8V airbag, TT foot pedals and possibly A6 climate controls haha!
    I’m going to buy one after a bit more research, match up wiring diagrams and see how it measures up.
    PT you make some good points on the Canbus side of things, weather it’ll actually turn the heated seats on as well too. I don’t remember seeing anything in VCDS either for any coding or adaptions for a climate control module.
  7. S3AMJ
    1,113
    301
    Excuse the quality of the pictures, I’m having to use what’s available to me on the internet. But from studying the connections closely and counting the number of pins... they are a 100% like for like! The only connector that differs between the two is the S3 8L has a 2 pin power connector and the A6 C6 has a 3 pin power connector. Even the size of the connectors look the same, who knows.... could be plug and play, very much doubt it though.
    S3 8L - Red / Black
    A6 C6 - Red / Black / Yellow - Green (earth)
    [​IMG]Audi S3 8L connectors
    [​IMG]Audi A6 C6 connectors
  8. S3AMJ
    1,113
    301
    Hi all, I’ve gone ahead and bought an A6 C6 climate control can someone kindly give me the measurements of the S3 8L climate control please?
    Length across the top and bottom and height from the centre? I can’t get the measurements until I go to where my car is stored for another week or 2
    Muchas gracias
  9. <tuffty/>
    23,195
    4,866
    Looked at my spares...
    Double DIN unit:
    227mm wide top edge, 208mm wide bottom edge, 79mm tall
    Single DIN unit:
    231mm top edge, 225mm bottom edge, 86mm tall
    S3AMJ likes this.
  10. S3AMJ
    1,113
    301
    Thanks PT, ok so I’ve measure the unit and I’ve got.
    Top length - 240mm
    Bottom length - 230mm
    Height from centre - 85mm
    Obviously lots of trimming involved on the sides and the bottom just like the A4 RNS-E. For the double dinn it’s going to be very tight on the bottom two buttons for the vent direction. Some of the chrome trim at the bottom will need to be trimmed and rounded at the edges to match.
    If you have a single dinn then it’ll be less to trim and easier to fit.
    Before I start trimming I’ll wire it all in and see if it communicates properly, functions, etc.
    Does look nice though!
  11. hydro s3
    hydro s3 S3 amk Team Ming Blue Audi S3
    835
    220
    43
    You looking to of load any of them spare ones?
  12. Avatar
  13. Daniel M
    Daniel M Member
    118
    13
    Was going to ask the same thing as they look great.
    hydro s3 likes this.
  14. <tuffty/>
    23,195
    4,866
    Not at this time mate soz
  15. hydro s3
    835
    220
    43
    No prob tuffty. You know what they say "if you don't as you don't get"
  16. S3AMJ
    1,113
    301
    Right.... well, this is going very slowly because I can’t even remove the existing climate control. I’ve tried everything, searched everywhere and everyone is saying, press down the top clips and pull it out?! I’m sorry but that’s just not right. This thing is not budging at all.
  17. warren9022
    warren9022 Active Member
    409
    168
    43
    Sounds right to me, my climate has come out using that method every time I’ve had it out. Does take a very forceful pull though.
    Tj 0785 likes this.
  18. S3AMJ
    1,113
    301
    It’s the bottom mate, it’s literally not wanting to come out to the point the whole center console wants to come out while I’m pulling from the back of it.
  19. warren9022
    409
    168
    43
    There’s 2 clips on the bottom as well but no way of getting to them hence the forceful pull to get it out, a lot of people break the bottom clips getting it out as it’s that tight!!
  20. S3AMJ
    1,113
    301
    Yeah I read about them bottom 2 but everyone makes out it just pulls out haha, it most definitely doesn’t. I’ll keep trying.....
  21. tcg
    tcg Well-Known Member
    763
    347
    warren9022 likes this.
  22. Ashy>>
    Ashy>> Active Member
    109
    41
    I had to remove my head unit first then "Yank the F*@K" out of it
    Tj 0785 and warren9022 like this.
  23. S3AMJ
    1,113
    301
    I’ve already done that haha, getting my hands down behind it and pulling like hell.... top two clips are free! Just not letting go at the bottom, the whole dash is moving as I’m pulling
  24. Ashy>>
    109
    41
    give it some more ugga duggas
    S3AMJ and warren9022 like this.
  25. S3AMJ
    1,113
    301
    Ok managed to do it, just slid a trim removal tool underneath and came out nice and easy! Right let’s see about this wiring next
  26. S3AMJ
    1,113
    301
    Ok I’m sorry gents but it would appear not to work, there is a humming sound coming from the heater blower, nothing turns on nor lights up. I’ll perhaps keep hold of it and maybe at a later stage when I can actually get my hands on some proper wiring diagrams for both the S3 and A6 climate control modules it’s a no show
  27. Ashy>>
    109
    41
    thats gutting as it looks a nice piece of kit too
  28. S3AMJ
    1,113
    301
    Yes very disappointed, I’ll revisit this once I’ve done a few other things.... I’ll post up any of my findings
