I have recently converted my 2001 Audi A4 b5 Avant Quattro 1.8T into a 2.5 TDI with the AFB v6. These are not available in the US - hence the conversion. I currently have the stock exhaust system with the two catalytic convertors. The cats were mostly blocked up so I cut the pipe and cleaned them as best I could (not sure if they are actually still working). The exhaust is quite smelly and sooty. I would like to clean the exhaust up.
My question is what aftermarket exhaust components can be retrofitted to this car/engine? There is not a lot of room under the car for cans. Maybe replace the center muffler?
I found one aftermarket combination diesel catalytic converter and DPF made by HJS (part number 93 11 2004). The image of the downpipe looks correct. I am not sure if the can will fit.
http://www.hjs-motorsport.de
I am also thinking of adding a methanoll/water injection setup to cool the gases and thereby reduce NOx emmissions. An Adblue systems looks to be a bit more complex with the tank, injector, and controls.
Other thoughts / ideas?
Thanks,
Sven
Thanks,
Sven
