Chrome Window Trim Removal
DanielF
Good morning All,
I was wondering if anyone could help with the knowhow to remove the chrome window trim of an a6 c7. I am dechroming using wrap on this car. I am new to the wrapping business and do not want to damage or force anything on their pride and joy. Is there anyone who can help please?
I have seen online the trim goes all the way from front to back above the doors. Is this correct?
Thanks in advance
beneadrian21
From what I know you'd have to thake the door cars off in order to remove the lower ones.
Sent from my SM-N950F using Tapatalk
B5NUT
Well-Known Member
You have to remove the window frame, not a quick or easy job. You're best leaving them in place
DanielF
Thanks, I will wrap on the car not an issue as done with s3's was not sure if the top trim comes off but no worries at all. Thanks for your help
jsosic
I want to bring this topic back to life, cause I want to replace my trims with the black ones. I would rather buy new from the stealers if they're not like 1000 euros lol.
This is what I found for the dissasmblement:
Now, I can't figure out part numbers of the black edition trims. How can I find those so I get the quote from the stealers?
RAF_S7
Well-Known Member
Gold Supporter
The black trims are expensive, and you may struggle to get any from the stealers without any damage.
I had my chrome wrapped in mat black on my S7. Really difficult to tell that it’s not OEM black, and a lot cheaper than replacing the actual trim :hi:
Easier to wrap and remove if you change your mind, and as others have already mentioned, it is not a simple job by any stretch of the imagination. Grab a roll of coloured tape to match the colour and finish you want, some knifeless tape, and you'll have a result near enough identical (depending on how well you do it, of course - best case scenario).
