Going to look at an S4 on Sunday and was wondering if there is a way to check cam timing using VCDS. I have done it on an R32 before and just wondered if there was same process?
Im assuming it would tell you the same thing as on the R32 so that you can see if there is sufficient slop to show wear in the tensioners / chains.
