  2. Dismiss Notice
Checking oil and coolant on 2009 S3 8P
J0N Sep 8, 2020
  1. J0N
    J0N Registered User
    554
    346
    I’m pretty new to this so please bear with me, I’ve only really used VCDS for scanning for faults.
    Measuring blocks? I want to check my oil and coolant temps as I believe I have an over cooling issue, maybe the thermostat.
    How do I go about doing this?
    Cheers (sorry).
  2. Avatar
    snack-media
    Advertisement
  3. processpaul
    processpaul New Member VCDS Map User
    20
    Open vcds
    Click Select Module
    Open engine module 01
    Click on ADV meas. values.
    Window opens to the right,
    Now type in Temperature in the top box that appears this will list anything with Temperature as a measuring point, tick the ones you want
    The values will display in the window to the left.
    J0N likes this.
  4. J0N
    J0N Registered User
    554
    346
    Brilliant, I’ll try that tomorrow.
  5. J0N
    J0N Registered User
    554
    346
    I had a bit of a play with measuring blocks, very interesting. I think the key is to not be afraid if VCDS and experiment a bit to find your way around....
  6. rum4mo
    rum4mo Registered User
    2,192
    557
    Yup, too many of us have VCDS but only push our selves when the need arises! I keep meaning to make up controller maps and typical field values for many parameters so that I can see what has gone wrong, or better going wrong, before trouble strikes!
    J0N likes this.
