  2. Dismiss Notice
Changing discs and pads
GeorgieS3 Feb 16, 2016
  1. GeorgieS3
    GeorgieS3 Registered User
    324
    75
    Need some advise of you guys?
    Went to Change my pads and discs today, following a very good guide on here. Now I got as far as pushing back the pistons back on the front and they wouldn't budge. Tbf I don't have the proper tool I tried bodging it with a g/clamp. But still the piston was so tight it only moved a few MM. Before the glamp broke!
    Would you recommend buying the proper tool? I thought they would go back relatively easy but the must be slightly siezed. Oh and I took the cap of the brake fluid tank as well.
    Cheers.
  2. Avatar
    snack-media
    Advertisement
  3. donfresh
    donfresh Registered User
    47
    Using the proper tools makes life so much easier
  4. GeorgieS3
    324
    75
    Yeah I thought as much, I read somewhere that the fronts are a lot easier to do without the re-wind tool. I will buy one now!
  5. <tuffty/>
    <tuffty/> Badger 5 Edition...Its all about the flow... Staff Member Moderator
    24,300
    5,574
    I assume you mean the rears... they need the proper tool as the piston winds in
  6. GeorgieS3
    324
    75
    I meant the fronts sorry, I know that I need the tool for the rears yes. I attempted the fronts today but couldn't get the piston to push back.
  7. <tuffty/>
    24,300
    5,574
    Fronts should just push back... I normally take the inboard pad out and reassemble using a lever bar in the gap against the disc to push the piston back
  8. GeorgieS3
    324
    75
    Yeah that's what I thought, thanks tuffty I will try that method. I took them completely of then tried using a g-glamp....until it snapped.
    Could it be possible it's siezed or just very hard to push back if the pads have been low for a while?
  9. <tuffty/>
    24,300
    5,574
    Can be stiff yeah hence using the natural environment to help force it back in....
    Undo the reservoir cap too and keep an eye on the fluid level as you may need to syphon some off
  10. GeorgieS3
    324
    75
    Right got both the front done today, with the pads being low so quite a while I pushed them in with a bigger and better g-clamp, then pumped the brake pedal to push them back out and repeated this until the Pistons went all the way back.
    Just need bedding in now and could do with some paint on the callipers but didn't have time today.
  11. TheRunningMan
    TheRunningMan Registered User
    80
    14
    Did you have to remove the caliper carrier to replace the discs? I've read differing opinions on whether this is necessary.
  12. Avatar
    snack-media
    Advertisement
  13. GeorgieS3
    324
    75
    I'm pretty sure you do need to take them off, no harm in giving them a clean as well.
  14. Stuart B
    Stuart B Registered User
    3,448
    743
    I got my old disks off with the carriers on but needed to loosen the carriers bolts to get new ones back on.
