  2. Dismiss Notice
changing allroad headlining and pillar trims....
dibbers Feb 23, 2021 at 10:21 AM
  1. dibbers
    dibbers New Member
    hi all, anyone any experience of the above - basically i am looking to replace the lighter elements (headlining and pillars) with a darker set from an S-Line. the B pillars look the most challenging, having the seatbelts thought them, but other than that, seems fairly straightforward?
    opinions / advice / experiences welcome! (i did search but found little)
  2. Avatar
    snack-media
    Advertisement
  3. LangChop
    LangChop Registered User
    43
    20
    I would disconnect the negative on the battery as you need to yank the A pillars a bit so they click, then you need to put a screw driver in to slide the three clips that holds it in place then you can see where it comes free. Hope that makes sense lol. I will post a pic of you want
  4. dibbers
    dibbers New Member
    yes that would be helpful. i did wonder about the battery, as although theres nothing live being taken out there are a few sensitive areas that need banging / poking / knocked!
  5. LangChop
    43
    20
    Hope you can see ok lol. The circled bit is where that black clip sits in. So once you pulled the A pillar towards you and it pops you then need to get a screw driver and slide the black clips x3 the way the arrow is pointing. But once you do it on your A pillar you will see the gap easier
    HTH
