Central locking problem after cruise control retrofit
beefys
Hi
I have a 2010 A3 2.0TDI 140 Sportsback S Line. After having a friend retrofitting cruise control to the car my central locking via the key fob stopped working. The central locking works fine using the drivers door lock and the drivers door interior lock switch. The key shows the red LED when I press the buttons on the fob. I took it to someone who used VCDS and he said that he could not access the convenience module to recode the key, so that may be the problem. I also have an aftermarket head unit a XTRONS Satnav/DVD player. Before the retrofit of the cruise control the head unit used to turn off when I removed the key however now it stays on and I have to manually put it to sleep. From reading the forums on here it thought it maybe the control module and had a look in the rear driver side boot but the module is not there. Cam anyone help?
BTW I have removed the cruise control and installed the original stalk back bit still have the same issues.
Thanks in advance
Sent from my SM-G955F using Tapatalk
NHN
Site Sponsor
What coding did he actually do.
Abi
How was the cruise control coded? I also have that radio fitted and did the Cruise retrofit last month on my 2010 A3 140 tdi. Coded it myself via vcds with no problems at all. Sounds like a coding fault. Hopefully the original code’s was saved? If so revert them back and code the cruise properly.
beefys
The coding was reverted back to what it was before the retrofit. He assured me that only 2 values were changed under section 16 and 17.
The original values were screenshot before changing and this was used to revert back.
Abi
Mmmm,
My coding was done via long coding helper, module 1 and module 9 from what I can remember.
beefys
I can only assume it's the control module itself. However I have no idea where it is and if it is even replaceable. I have only one key so I can't also do the self key coding if that would help the problem.
Abi
You can code keys in central electric’s module 9 under adaptation! My memory recalls
beefys
We tried this. The problem isn't with the key itself. The VCDS can see the key and also acknowledges the key press. The issue is we can't save the new value because it can't communicate to the module. We checked the fuses in the engine bay and the side of drivers door bit all were fine.
ch1z64
C'mon you's bhoy's in Green
Silver Supporter
You might want to update your Vcd's cable if its genuine as it is 18.2.1 version they use now.
Abi
Not sure what my vcds version is, can’t check till home fr work later.
beefys
The photo shows the VCDS we used on the initial retrofit. When we changed the values back to how they were I had to pay someone to come out and do it as my mate was unavailable. I have contacted the person I paid and he has said he is using the latest version with an original RossTech cable.
Abi
How come values were changed in section 17 ‘instruments’ as I didn’t
beefys
I'm not sure about the coding sections. I think my friend was following a step by step guide when he done it. But he has assured me many times that the only 2 values he changed was the 2 pics he took. When I paid for the coding to be changed back these 2 values were only changed.
ch1z64
Silver Supporter
I take it you never took a pic or 2, off the pics the other guy did when he changed the coding back to what it was before you did the retrofit , as that could help .
Did you do an Autoscan b4 you changed any coding .
The guy you paid was he not able to tell you if the module you had in the car was capable off taken Cruise Control.
beefys
The 2 pics are taken before the change. We used the same pictures to enter the original values back. I'm not sure if an Autoscan was carried out initially.
ch1z64
Silver Supporter
I would get the guy you paid to come back and retrace what you tried to do and add the cruise control and see if he can recode for you as you have nothing to loose if he does an autoscan first as this will safe all coding b4 you change it
Or you could seek the retrofitters from the site for a small fee to fix for you @Ash187 or @NHN
Abi
I could post you pictures of the the codes off my vehicle if you would like (being the same vehicle), but can’t do that till Thursday as my laptop is at girlfriends and cable is at mine.
Regarding the software not communicating with the module, I’m no expert but all I can think of is the cable is no longer authorised, this can be checked by opening vcds and going to ‘options’
Hope this helps
beefys
Thanks for your help. Yes please can you send screenshots when you get a chance and I can compare mine. Is there anyone close to Birmingham that has VCDS that I can visit to get a Autoscan done?
ch1z64
Silver Supporter
Hope this helps
The Cable should be fine if its a genuine one , only need to plug into comp and update to the newest version 18.2.1
ch1z64
Silver Supporter
Hope this helps
Your car even tho the same age it would need to have all that he has in his ie ambient lighting , footwell lights etc for your code to help him , so best you send him pics off all the bytes and bits which will allow him to see what you both have and compare . Maybe PM him and get email addy
Abi
Yes I agree ‘sorry wasn’t thinking’ still learning about vcds, and coding
ch1z64
Silver Supporter
Thats not a problem at least your trying to help the guy , everyday is a School day
beefys
Have booked it for the weekend for VCDS will post the results here.
ch1z64
Silver Supporter
If you have it booked in take your retrofit stuff and get the guy there to code for you , if he knows his way around vag he should be able to code for you or be able to tell you if it can be added
ch1z64
Silver Supporter
My version is 16.80 unfortunately I can’t upgrade.....
I used to have 1 off those 16.8 cables ( clone ) worked fine for a while then it started throwing up faults amd stupid me would go buy the sensors and find out later they never need changed so ended up buying the correct 1 and never a problem since
Abi
I can only gather is not gen as you could upgrade via Ross-Tech :thumbs up::thumbs up:
Mmmm...
yes! bought off EBay about 3 years ago, only mainly use it to reset service intervals on my girlfriends and my A3 but have used it more on mine to activate cornering lights and other little tweaks plus cruise control most recently.
Abi
Never had a problem in 3 years with this one.
Abi
My last comment on here, as other peeps know more about this than me.
I followed all the coding process step by step on the ‘Cruise Control retrofit guide’ thread on here and worked perfectly first time. Even with my vcds version!
beefys
Thanks for your help mate. I'll try the VCDS this weekend as said and see if it sheds any light on the matter.
Abi
Did you have any luck at the weekend?
ch1z64
Silver Supporter
I think this is going to be another one off the unfinished threads lol
beefys
Hi
Sorry about the late reply. Unfortunately couldn't get it diagnosed as the guy had some family emergency. I will update the thread when I have the readings. Might be this weekend
Abi
Hi
Did you get your car’s central locking sorted in the end?
beefys
After a year got it sorted. The BCM module under the steering wheel was changed and connected it to vcds. Done a key adaption and now is working fine. Before this I did notice a few wires sliced in the driver door loom bit that didn't fix the problem. Was the BCM in the end.
Reactions: Abi
