So tonight pulled on the drive way .. left the car in a position i wouldnt normally so went back to the car to move it and couldnt get it out of park. Found this very odd as id just drove it onto the drive minutes before. Could hear the brake switch/release under gear selector/knob working but tried over ride button located in storage compartment in front of gear selector anyway with zero joy !! Realising the button had stayed inside the gear knob i removed it as it should be well probably alot easier than it should of as i found the plastic shaft has crumbled/snapped well basically broke inside the gear knob. My 1st question is i have a warrenty on the car as ive only owned it 2 and abit months do we think this will be covered ? Other question is the cars stuck and refusing the select gears eventhough i can operate the plastic shaft with my fingers. Does anyone have any ideas on repair prices ? Im also assuming the whole unit will requiring replacing and not just the shaft ..
Ive googled such a problem and im either very unlucky and this is a freak break or someone has been in there before which is just my luck aswell !!
any advice would be greatly appreciated !!
Thanks in advance !!
